Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: FP Question/Request
    Constant Bitrate Subwoofer87's Avatar
    Nov 2004
    FP Question/Request
    Will the future release of FP support AAC (.m4a) music files? This would be very helpful as I have a ton of these files. They are much better than mp3 files because they are smaller in size and can have a better quality (ie 1mp3 192kbit = 1aac 128kbit)
    Thanks,
    Nick
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Subwoofer87
    Thanks,
    Nick
    The current version already does. You just need to install quicktime alternative and add the extension.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nov 2004
    I already have quicktime installed I shouldn't need it? I'm going to install it anyways and see how well it works.
    Nov 2004
    I installed quicktime alternative and nope, i still can't find my files when I update the database.
    Jan 2005
    you have to add the extension to your database
    in settings1 -> file types -> add extension
    then you have to add m4a and it should work now
    Nov 2004
    I had that in there before I installed the alternative. Do I need to remove it and readd it or is that not the problem?
    Nov 2004
    Nov 2004
    I reinstalled the quicktime alternative, removed and added m4a (and aac just in case) in th file types in fp, and I still cannot play my m4a files. I tried playing them in WMP but that didn't work either, if that helps anyone.
    Aug 2004
    Germany
    Well at least it's not a problem with FrodoPlayer then. If everything is installed correctly you should at least be able to play it in WMP. If you get it to run there it'll also work in FrodoPlayer.
    Nov 2004
    Well I followed the steps correctly. I have a working copy of windows and it still doesn't work. has anyone else recieved any problems like this?
  1. Problem watching movies with FP & Powermate
    By maxxell in forum FP Bug Reports
    Last Post: 04-09-2005, 11:36 AM
  2. Back and forth FP <-> D3-frontend
    By swissRv in forum Map Monkey
    Last Post: 11-08-2004, 04:53 AM
  3. Boy this is annoying - No volume in FP
    By voidunknown in forum FrodoPlayer
    Last Post: 10-20-2004, 01:18 PM
  4. Basic install Instructions for new FP user
    By eazyrog in forum FrodoPlayer
    Last Post: 10-13-2004, 06:04 PM
  5. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-13-2004, 12:58 AM
