My money is in the OS, there is something crucial for the App that you SYS is missing.
Printable View
I keep the music on the same drive. And just tried safe mode and got the same results....The wierdest part is I never changed anything with my system I just started my car like I normally do and it stopped working....
What about a recovery from the Win cd?? (it will add OS files that are missing without touching your APPs) because there is nothing else that I can think of that is causing the problem.
Good luck.
THanatos.
Ok new update....when I started Safe mode without networking I got this error.."8/21/2005 - 4:03:15 PM - 10050 - Network subsystem failed - frmWebServer-ListenForConnections - 0 - Winsock - "
I also noticed something else. When I have the medialib.ldb I still get the windows error, but nothing is written to the errorlog file. When I delete that file and get the same error, it writes that same line to the log file.
I attached a new log file.
zip up your medialib.mdb and post it
also post your frodoplayer.ini file
Well the server error is because FP has a build server conection (that is why when you install the program and run it fro 1st time windows show you that pop up asking you what to do with that block or unblock)
Zip and ini files
have you tried doing a system restore back to a point in time when it was working?
Wish I could but Sys Restore is off to save space and boot time...
DVD_DRIVE=L:
CD_DRIVE=G:
VIDEO_PATH=D:\Music Videos
DB_ROOT=D:\
Do these exist ?
