Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: Frodo won't lauch - Log frmDB Error
    Low Bitrate BlueGrimRX8's Avatar
    Dec 2004
    Jacksonville
    The other day when I got into my car and my PC started up, when Frodo attemted to start I got the I get the Error: MultiMedia Player for In-Car Use has encountered a problem and needs to close.
    I didn't change anything, I hadn't had any problems shutting down or starting up, I just got in the car and this started.
    I took a look at the log file and this is what it says:
    "08/20/2005 - 2:00 PM - 52 - Bad file name or number - frmDB-Form_Load - 0 - FrodoPlayer"
    Dows anyone know what could have went wrong or how to fix it?
    Thanks a lot for the help!!!
    James
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    THis is a database error..... it happened to me when I forgot to turn on the ext HD in my testing machine.
    Go to setting 1 and rebuild you database, and see what happen then.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Dec 2004
    Jacksonville
    I can't even get to the settings, Frodo won't even load it just starts to open then gives me the error. I tried unistalling and reinstalling. I tried redownloading and reinstalling too......
    Nov 2004
    Do you have a file call medialib in you FP folder??
    Nissan Aux-in MOD
    Nov 2004
    For sure you are missing a file or for some reason or one of the .dll haven't register right (I might be wrong).
    Nissan Aux-in MOD
    Nov 2004
    Also try to manually change to the default skin in the .ini file (that if you are using a custom skin).
    Nissan Aux-in MOD
    Dec 2004
    Jacksonville
    I have the Medialib file in the folder and don't have a custom skin. It is a completly fresh install from the download on frodo's site.
    Is there a way to manually register all the dll's?
    Nov 2004
    think that I was wrong from the begining. I just check my other PC and the log is no the same.
    To manually reg the .DLLs you go to run type cmd then when in the command prompt type C:\Program Files\FrodoPlayer then you just type regsvr32 and the name of the .dll.
    Sorry if I make you waste you time with wrong inst.
    Thanatos.
    Nissan Aux-in MOD
    Dec 2004
    Jacksonville
    Well I think I have tried everything short of reinstalling windows (which I REALLY don't want to do). Any other suggestions.....?
    Jan 2003
    Ruston, LA
    post up the log
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
  3. Error message on Gps with frodo & guidance
    By biglips31 in forum GPS
    Last Post: 01-27-2005, 11:13 AM
  4. Frodo error
    By asci01 in forum FrodoPlayer
    Last Post: 06-20-2004, 11:55 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
