Maybe is because you are controlling the wave volume in FP.
Thanatos.
I just installed my carpc and I was trying out a few different frontends. I started with roadrunner and it was ok. But I then tried FP and kept everything the same.... the volume was ALOT louder. I had RR turned all the way up and it was ok, I go into FP and it was at 25% volume and it was as loud as RR at 100% volume. What gives? I am not complaining as I can cut the amp down a little and keep the weird ground noises to a minimum with it at the lower input. Plus FP runs alot better on my EPIA 800mhz machine than RR does.
THANK YOU FRODO!!!!!!!![]()
Thanatos.
Hmmm... I had everything all the way up in the advanced volume controls. Oh well. I still am leaning very heavily toward FrodoPlayer over RR. Plus it is much faster and less buggy on my setup. Always a plus.
I like it too
Thanatos.
