Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 132
Thread: FP 1.10 Release (It may be a turd)
  1. #91
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by Tribune-Maximus
    @ Frodo
    Hey, Frodo...i love your player and the new updates!!!
    But i have the same problem as KONRAD !
    (if i press close or return...the navi window closes fully my MapMonkey)
    How can i fix this?? Are there specific .ini entries??
    Is there something i do wrong??
    plz help!
    regards
    tribune
    Just to clarify this issue, and as patz found out, this is because your version of windows is not using the . as a decimal point separator.
    Just edit the embedskin.ini with notepad and replace the . with the character you are using - , in my case.
    HIDE_LEFT=82.5
    HIDE_TOP=0
    HIDE_WIDTH=17.5
    HIDE_HEIGHT=10
    HIDE_LEFT=82,5
    HIDE_TOP=0
    HIDE_WIDTH=17,5
    HIDE_HEIGHT=10
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  2. #92
    Newbie Tribune-Maximus's Avatar
    Dec 2004
    Quote Originally Posted by Bravellir
    Thx a lot...that works fine for me
    tribune
    Shuttle FE22 P3-800MHz C3, 512MB RAM
    Morex 3688 black, CarTFT-M1-PowerSupply
    Lilliput 7" Touchscreen TFT Monitor
    Holux GM-210 GPS USB Device
    Ovislink WL5480 WLan Device / 8dbi
    24Bit USB Soundcard
  3. #93
    Nov 2005
    Australia
    Is anyone else experiencing problems with the playlist function. Existing playlists are being read but attempting to save a new list results in an empty file.
  4. #94
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Genre mode bug
    I have the same issue with the play lists! It saves an empty file... But I also have this other VERY annoying problem... When I have Genre mode Fordo does the following:
    I have the number of the genre showing up in front of the genre category. I think it only happens to for the songs that have both ID3V1 and ID3V2 tags. So I get to different genre listing for each type... one with the number for songs with both tags and one without the number for songs with one tag! Can I make FrodoPlayer ignore one tag or something??? Frodo help!!! It is very annoying since that is my primary way of browsing my music
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5 SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  5. #95
    Illinois
    Quote Originally Posted by helitroppo
    yep, i posted about this on the first page
  6. #96
    Feb 2005
    When I try to use the embedder function with for example notepad, it opens in a new window (= not embedded). Anyone with the same problem who knows the solution to this?
    I have done no changes to frodoplayer.ini exept this:
    GENERIC_GPS_PATH=C:\WINDOWS\notepad.exe
  7. #97
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    make sure you set the title of the window to be correct..
  8. #98
    Feb 2005
    Boston,MA
    Jisc also try to increase the delay. This is the time frodoplayer waits until it will try to find the specified window and embedd it. If the application hasn't start completrly in thaat time FP is unable to find it an it does not embedd it. Try 10000 ms for start, then decrease it to the time actyaly needed buy just counting thr seconds the app thakse to fully lunch
  9. #99
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    Same thing here. Tried increasing delay with no luck. Not sure what's going on
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
  10. #100
    Feb 2005
    Boston,MA
    are u sure you got title of the window correct? double check that. For instance notepad should be *Notepad. I use the star since the first part of the window name chances to whatever the document is called.
  1. (RELEASE) FP 1.09 Take 3
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-09-2007, 11:40 AM
  2. FP 1.09 Girder Sample File Release
    Last Post: 12-07-2004, 01:09 PM
  3. (RELEASE) FP 1.09 Take 2
    Last Post: 10-28-2004, 10:31 PM
  4. FP 1.09 Release was "..." :)
    Last Post: 10-19-2004, 10:33 PM
  5. FP 1.09 Test Source Release for Windows Messages.
    Last Post: 10-05-2004, 12:49 AM
