[MAIN]
LASTCAPTION=20 Fingers ft Gillette - Mr Personality (Album Version).mp3
RADMUTEUNMUTE=TRUE
XMMUTEUNMUTE=FALSE
MUTERADLINE=TRUE
MUTEXMLINE=FALSE
BUILTINGPS=3
VISOFFENABLED=TRUE
FRODOWEB_IP_ADDRESS=192.168.0.2
MINIMODEONTASKSWITCH=TRUE
VOLUMESHOWSDECIMALS=FALSE
FSPLAYLISTVISIBLEUNTILYOUSAYNO=TRUE
BBAAFOLDERSIZE=128
JUMPFROMMAIN=FALSE
RETURNTOMENUFROMFUNCTIONS=FALSE
SHOWMENUATSTART=TRUE
KEEPMENUOPENUNTILCLICKED=TRUE
CURRENTSORTMODE=0
DVDSHOULDRESUME=FALSE
DVDLASTID=0
DVDLASTTITLE=0
DVDLASTPOS=0
MODE_ARTIST_ENABLED=TRUE
MODE_ALBUM_ENABLED=TRUE
MODE_GENRE_ENABLED=TRUE
MODE_DIRECTORY_ENABLED=TRUE
MODE_CD_ENABLED=TRUE
MODE_PLAYLISTS_ENABLED=TRUE
MODE_FAVORITES_ENABLED=TRUE
MODE_BBAA_ENABLED=TRUE
MODE_BBD2_ENABLED=TRUE
SHOWFILENAMESINPLAYLIST=true
HIDEMOUSEDVDPOSITION=TOPRIGHT
FILTERID3=FALSE
HIDECURSORGLOBAL=false
WHEN_EXIT_BBAA_BY_KEY_ESCAPE_DEFAULT_RETURN_RECURS IVE=False
VOLUME_SPEED=16
VOLUME_UPDATE_SPEED=100
VOLUME_UP_DOWN_1_PERCENT=1
VOLUME_UP_DOWN_2_PERCENT=3
SHOW_TRACK_NUMBERS=FALSE
LOCKOUTENABLED=TRUE
LOCKOUTONHIGH=TRUE
LOCKOUTPORT=1
FF_RR_NEXT_PREV_SAME_BUTTON=True
XM_PORT=3
XM_VOL_CONTROL=LINE
SCROLLPIXELJUMP=10
SCROLLTIME=500
LBLSCROLLARTISTENABLED=TRUE
LBLSCROLLALBUMENABLED=TRUE
LBLSCROLLTITLEENABLED=TRUE
FSSTATUSALWAYSVISIBLE=TRUE
FSMENUALWAYSVISIBLE=TRUE
FSSLIDERALWAYSVISIBLE=TRUE
TOOLTIPS=FALSE
FIRSTUSE=FALSE
THOUSANDSEPERATOR=.
VOLUMESTARTAT100=FALSE
REQUIREPASSWORD=FALSE
PASSWORD=3341
CLEAR_LIST_MODE_CHANGE=FALSE
SCROLLBUTTONREVERSE=FALSE
CHECK_FOR_FILE_CHANGE=FALSE
USE_ADVANCED_SCREEN_SETTINGS=TRUE
SHORTCUT_SHUTDOWN=TRUE
SHUFFLE=TRUE
REPEAT=FALSE
BBD_RECURSE=TRUE
DVD_DRIVE=D:
DVD_EXTERNAL=FALSE
DVD_APP_PATH=NONE
DVD_APP_CLO=NONE
DVD_EXTERNALPAUSE=TRUE
DVD_MINI=FALSE
CD_DRIVE=D:
VOL_MASTER=TRUE
TIME=REMAINING
ALBUM_ART=CHANGE
ALBUM_ART_ENABLED=TRUE
INFO=CHANGE
VIDEO_PATH=C:\MP3
DB_ROOT=C:\MP3
DAYSKIN=brushed_alum
DAYTIME=7:00:00 AM
NIGHTSKIN=brushed_alum
NIGHTTIME=8:00:00 PM
FULLSCREENMODE=2
PLAYLISTMODE=1
MINSCROLLDIRECTION=RIGHT
MAG_ENABLED=FALSE
MAGSCALE=1
MAGINVERT=FALSE
CLICK_SOUNDS=TRUE
MODE=5
FILE_LAST_PLAYED=NONE
FILE_LAST_PLAYED_POSITION=0
LAST_VOLUME=1360
VISMODE=1
VOICES_ON=FALSE
PREVIOUS_VOICE=TRUE
REWIND_VOICE=TRUE
PLAY_VOICE=TRUE
PAUSE_VOICE=TRUE
STOP_VOICE=TRUE
FASTFORWARD_VOICE=TRUE
NEXT_VOICE=TRUE
VOLUME_VOICE=TRUE
MUTE_VOICE=TRUE
VIS_OR_INFO_VOICE=TRUE
SEARCH_VOICE=TRUE
SHUFFLE_VOICE=TRUE
REPEAT_VOICE=TRUE
MODE_VOICE=TRUE
MENU_VOICE=TRUE
DVD_VOICE=TRUE
SETTINGS_VOICE=TRUE
EXIT_VOICE=TRUE
APPS_VOICE=TRUE
TITLE_VOICE=FALSE
JUMP_VOICE=TRUE
RADIO_VOICE=TRUE
GPS_VOICE=TRUE
XM_VOICE=TRUE
PREVIOUS_VOICE_STRING=Previous
REWIND_VOICE_STRING=Rewind
PLAY_VOICE_STRING=Play
PAUSE_VOICE_STRING=Pause
STOP_VOICE_STRING=Stop
FASTFORWARD_VOICE_STRING=Fast Forward
NEXT_VOICE_STRING=Next
VOLUME_UP_VOICE_STRING=Volume Up
VOLUME_DOWN_VOICE_STRING=Volume Down
MUTE_ON_VOICE_STRING=Mute On
MUTE_OFF_VOICE_STRING=Mute Off
SEARCH_ACTIVATE_VOICE_STRING=Activating Search
SEARCH_DEACTIVATE_VOICE_STRING=Deactivating Search
JUMP_ACTIVATE_VOICE_STRING=Activating Jump
JUMP_DEACTIVATE_VOICE_STRING=Deactivating Jump
SHUFFLE_ON_VOICE_STRING=Shuffle is On
SHUFFLE_OFF_VOICE_STRING=Shuffle is Off
REPEAT_ON_VOICE_STRING=Repeat is On
REPEAT_OFF_VOICE_STRING=Repeat is Off
MENU_VOICE_STRING=Activating Menu
DVD_VOICE_STRING=Launching DVD Player
SETTINGS_VOICE_STRING=Edit Program Settings
EXIT_VOICE_STRING=Frodoplayer is Shutting Down
APPS_VOICE_STRING=Launching External Applications
RADIO_VOICE_STRING=Launching FM
Radio
GPS_VOICE_STRING=Launching GPS
XM_VOICE_STRING=Launching XM Radio
KEY_VISUALIZATION=27
KEY_ALBUM_ART=27
KEY_INFO=27
KEY_MAG=27
KEY_FULLSCREEN=27
KEY_DOWN=27
KEY_UP=27
KEY_LEFT=27
KEY_RIGHT=27
KEY_APP1=27
KEY_APP2=27
KEY_PLSBUILD=27
KEY_PREVIOUS=90
KEY_REWIND=88
KEY_PLAY=67
KEY_PAUSE=86
KEY_STOP=66
KEY_FASTFORWARD=78
KEY_NEXT=77
KEY_SHUFFLE=27
KEY_REPEAT=27
KEY_MUTE=27
KEY_VOLUME_UP=27
KEY_VOLUME_DOWN=27
KEY_SEARCH=27
KEY_SETTINGS=27
KEY_SETTINGS2=27
KEY_DVD=27
KEY_APPS=27
KEY_EXIT=27
KEY_MINI=65
KEY_SHUTDOWN=27
KEY_STANDBY=27
KEY_HIBERNATE=27
KEY_ARTIST=27
KEY_ALBUM=27
KEY_GENRE=27
KEY_DIRECTORY=27
KEY_ALL_MUSIC=27
KEY_ALL_VIDEO=27
KEY_CD=27
KEY_BBAA=27
KEY_BBD2=27
KEY_PLAYLISTS=27
KEY_LOGOFF=27
KEY_LOCKCOMPUTER=27
KEY_RADIO=27
KEY_GPS=27
KEY_XM=27
KEY_FAVORITES=27
KEY_DIRLIST_DOWN=87
KEY_DIRLIST_UP=81
KEY_DIRLIST_LEFT=65
KEY_DIRLIST_RIGHT=83
KEY_DIRLIST_SELECT=69
KEY_PLAYLIST_DOWN=71
KEY_PLAYLIST_UP=70
KEY_PLAYLIST_SELECT=27
KEY_MINIMIZE=85
KEY_TASK=27
KEY_VOLUME_UP_2=27
KEY_VOLUME_DOWN_2=27
MODIFIER_KEY_VISUALIZATION=0
MODIFIER_KEY_ALBUM_ART=0
MODIFIER_KEY_INFO=0
MODIFIER_KEY_MAG=0
MODIFIER_KEY_FULLSCREEN=0
MODIFIER_KEY_DOWN=0
MODIFIER_KEY_UP=0
MODIFIER_KEY_LEFT=0
MODIFIER_KEY_RIGHT=0
MODIFIER_KEY_APP1=0
MODIFIER_KEY_APP2=0
MODIFIER_KEY_PLSBUILD=0
MODIFIER_KEY_PREVIOUS=2
MODIFIER_KEY_REWIND=2
MODIFIER_KEY_PLAY=2
MODIFIER_KEY_PAUSE=2
MODIFIER_KEY_STOP=2
MODIFIER_KEY_FASTFORWARD=2
MODIFIER_KEY_NEXT=2
MODIFIER_KEY_SHUFFLE=0
MODIFIER_KEY_REPEAT=0
MODIFIER_KEY_MUTE=0
MODIFIER_KEY_VOLUME_UP=0
MODIFIER_KEY_VOLUME_DOWN=0
MODIFIER_KEY_SEARCH=0
MODIFIER_KEY_SETTINGS=0
MODIFIER_KEY_SETTINGS2=0
MODIFIER_KEY_DVD=0
MODIFIER_KEY_APPS=0
MODIFIER_KEY_EXIT=0
MODIFIER_KEY_MINI=2
MODIFIER_KEY_SHUTDOWN=0
MODIFIER_KEY_STANDBY=0
MODIFIER_KEY_HIBERNATE=0
MODIFIER_KEY_ARTIST=0
MODIFIER_KEY_ALBUM=0
MODIFIER_KEY_GENRE=0
MODIFIER_KEY_DIRECTORY=0
MODIFIER_KEY_ALL_MUSIC=0
MODIFIER_KEY_ALL_VIDEO=0
MODIFIER_KEY_CD=0
MODIFIER_KEY_BBAA=0
MODIFIER_KEY_BBD2=0
MODIFIER_KEY_PLAYLISTS=0
MODIFIER_KEY_LOGOFF=0
MODIFIER_KEY_LOCKCOMPUTER=0
MODIFIER_KEY_RADIO=0
MODIFIER_KEY_GPS=0
MODIFIER_KEY_XM=0
MODIFIER_KEY_FAVORITES=0
MODIFIER_KEY_DIRLIST_DOWN=0
MODIFIER_KEY_DIRLIST_UP=0
MODIFIER_KEY_DIRLIST_LEFT=0
MODIFIER_KEY_DIRLIST_RIGHT=0
MODIFIER_KEY_DIRLIST_SELECT=0
MODIFIER_KEY_PLAYLIST_DOWN=0
MODIFIER_KEY_PLAYLIST_UP=0
MODIFIER_KEY_PLAYLIST_SELECT=0
MODIFIER_KEY_MINIMIZE=2
MODIFIER_KEY_TASK=0
MODIFIER_KEY_VOLUME_UP_2=0
MODIFIER_KEY_VOLUME_DOWN_2=0
APP1MINI=TRUE
APP1COMMANDLINE=NONE
APP1COMMANDLINEOPTIONS=NONE
APP1PAUSE=FALSE
APP2MINI=TRUE
APP2COMMANDLINE=NONE
APP2COMMANDLINEOPTIONS=NONE
APP2PAUSE=FALSE
APP3MINI=TRUE
APP3COMMANDLINE=NONE
APP3COMMANDLINEOPTIONS=NONE
APP3PAUSE=FALSE
APP4MINI=TRUE
APP4COMMANDLINE=NONE
APP4COMMANDLINEOPTIONS=NONE
APP4PAUSE=FALSE
APP5MINI=TRUE
APP5COMMANDLINE=NONE
APP5COMMANDLINEOPTIONS=NONE
APP5PAUSE=FALSE
APP6MINI=TRUE
APP6COMMANDLINE=NONE
APP6COMMANDLINEOPTIONS=NONE
APP6PAUSE=FALSE
APP7MINI=TRUE
APP7COMMANDLINE=NONE
APP7COMMANDLINEOPTIONS=NONE
APP7PAUSE=FALSE
APP8MINI=TRUE
APP8COMMANDLINE=NONE
APP8COMMANDLINEOPTIONS=NONE
APP8PAUSE=FALSE
APP9MINI=TRUE
APP9COMMANDLINE=NONE
APP9COMMANDLINEOPTIONS=NONE
APP9PAUSE=FALSE
APP10MINI=TRUE
APP10COMMANDLINE=NONE
APP10COMMANDLINEOPTIONS=NONE
APP10PAUSE=FALSE
SUPERSEARCH=3
SEARCHAUTO=TRUE
LASTTYPELISTINDEX=0
LASTPLAYLISTINDEX=0
LASTPLAYLISTTEXT=NONE
POWERFORCE=TRUE
FILECOUNT=0
HASHDATE=12:00:00 AM
RADIATOR_PATH=C:\Program Files\Radiator\radiator.exe
LAST_RADIO_STATION=10610
RADIO_VOL_CONTROL=LINE
RADIO_EXTERNAL=TRUE
RADIO_APP_PATH=NONE
RADIO_APP_CLO=NONE
RADIO_EXTERNALPAUSE=TRUE
RADIO_MINI=FALSE
XM_EXTERNAL=FALSE
XM_APP_PATH=NONE
XM_APP_CLO=NONE
XM_EXTERNALPAUSE=FALSE
XM_MINI=FALSE
GPS_EXTERNAL=FALSE
GPS_APP_PATH=C:\
WINDOWS\NOTEPAD.EXE
GPS_APP_CLO=C:\Documents and Settings\Kevin\Desktop\FrodoPlayer\HWG\fp109girder .GML
GPS_EXTERNALPAUSE=FALSE
GPS_MINI=FALSE
PLBUILD_VOICE_STRING=Launching Playlist Builder
PLBUILD_VOICE=TRUE
JUMP_VIS_VID_ON_PLAY=FALSE
LASTTYPELISTTEXT=NONE
[ADVANCED]
ADV_TOP=200
ADV_LEFT=100
ADV_WIDTH=800
ADV_HEIGHT=480
[MINI]
MINI_LEFT=77000
MINI_TOP=3100
[LAUNCHONRESUME]
RESUMECOMMAND=NONE
RESUMECOMMANDLINEOPTIONS=NONE
[LAUNCHWITHFRODO]
LWFCOMMAND=NONE
LWFCOMMANDLINEOPTIONS=NONE
[FRODOCAM]
FRAMERATE=15
STRETCH=TRUE
BACKCOLOR=0
STARTWITHMENUOPEN=FALSE
CAMTRIGGERENABLED=FALSE
CAMTRIGGERONHIGH=TRUE
CAMTRIGGERPORT=1
[FRODOPICTURES]
SLIDESHOW_TIME=800
BACKCOLOR=0
DEFAULTPATH=C:\Documents and Settings\Kevin\Desktop\content!_files
STARTWITHDIRMENUVISIBLE=TRUE
[GPSDEFAULTPATHS]
GENERIC_GPS_PATH=C:\WINDOWS\NOTEPAD.EXE
GENERIC_GPS_COMMAND_LINE_OPTIONS=NONE
GENERIC_WINDOWTITLE=*Notepad
GENERIC_WAIT_BEFORE_LOOK=1000
