Results 1 to 6 of 6
Thread: half screen frodo when launched
    Oct 2005
    Unhappy half screen frodo when launched
    Hello everyone evrytime I start frodo it only shows half of screen I can not exit or change because only shows upper part, the only way to fix is either change it the resolution or if I moved the taskbar from one side to other can anyone help I've reading but hav'nt found anything like it.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    Advanced screen settings.... its in the FAQ
    Oct 2005
    Thanks man I'll try to see if works, but Im a bit consufed i tried doing from the settings still the same, now if I do it from tha ini. file I should change to false instead of TRUE ..right???
    Aug 2004
    Pearland
    yes i believe so...
    Oct 2005
    Thumbs up
    hey it works!! finally I was going crazy.
    Aug 2004
    Pearland
    I do have to say i found it quite ironic to see you use the smiley.. when it was in the FAQ...
  1. Faulty second hand LCD screen,, need help!
    By mongo_pete in forum LCD/Display
    Last Post: 06-22-2005, 07:37 PM
  2. Comps Specs and Screen Size
    By Rocky388 in forum Newbie
    Last Post: 05-31-2005, 09:37 PM
  3. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 08:07 PM
  4. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
