Results 1 to 3 of 3
Thread: 2 soundcards
    Slovenia (EU)
    2 soundcards
    Hi all,
    I am using a VIA EPIA SP13000 mainboard and Terratec Cinergy 600 (TV+FM PCI card). The sound from Cinergy comes in computer through Line-in.
    I also have two soundcards. One on mainboard and the USB Audigy 2 NX.
    Now I would like to use USB soundcard for output every sound. But for Line-in I would like to use mainboard soundcard. I am using Radiator through FrodoPlayer for FM. I tried to set sound recording device as VIA's soundcard, but Radiator still reads only from USB.
    Any help apriciated,
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    I've also a problem like yours, but i think that you can use only one sound card at the same time.
    CarPC in Progress [||||||||-] 90%
    Visit my Project
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    From my experience the line in can only be played by the same card. Unless you first store it in the HD you canít play it from an other card. That is because the signal is not digitized until you save it. It is still analog so it can't be transferred to the other sound card. Hope I helped.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5Ē SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  1. External USB Soundcards...
    By RoyN in forum Car Audio
    Last Post: 11-19-2005, 10:19 AM
  2. Soundcards By ONKYO
    By CL_lover in forum Car Audio
    Last Post: 04-10-2005, 09:42 PM
  3. Replies: 1
    Last Post: 06-11-2004, 02:10 PM
  4. onboard vs external soundcards
    By Cardog in forum General Hardware Discussion
    Last Post: 02-13-2004, 12:04 PM
  5. Hybernation and soundcards
    By kiddigital in forum General Hardware Discussion
    Last Post: 03-01-2002, 12:53 AM
