Results 1 to 10 of 14
Thread: Connect/Disconnect internet connection
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Is it possible to set up some sort of app or something in frodo to access my dial-up networking connection with my bluetooth phone... i want to be able to connect/disconnect the internet connection without having to go to my taskbar and do it that way
    Debating on installing a carpc in my Jeep.....
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Shortcut or add to favorites and access to it via browser.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Elsewhere
    Quote Originally Posted by thanatos106
    I think you also need to set the bluetooth conenction as your default connection... Or at least set to 'dial' that connection when there's no other network connection present.
    That's all in the browser settings.
    How about the Wiki?
    Nov 2004
    well I was talking about the hole "connections" (so you can see all your connections) but I guess you're right too.
    Thanatos.
    Nissan Aux-in MOD
    Jul 2004
    Tampa, FL
    ok i setup a shortcut in the apps menu to open the connection dialog... but i am not able to disconnect the connection without minimizing frodo and clicking the connection in the taskbar to disconnect... any way to make a shortcut to disconnect the connection?
    Nov 2004
    Post a pic. (why no a shortcut to network connections and administrate it from there?)
    Thanatos.
    Nissan Aux-in MOD
    Jul 2004
    Tampa, FL
    heres what comes up with the shortcut i have now
    Nov 2004
    You can change that in properties (so it doesnt it display that win everytime)
    So when you are connected and double click the shrotcut it does give you a disconnect button?
    Thanatos.
    Nissan Aux-in MOD
    Jul 2004
    Tampa, FL
    when im connected it pulls up the same screen in my screenshot
    Nov 2004
    make a .bat file with this lines (the connection has to be set as default)
    rundll32 iedkcs32.dll,CloseRASConnections
    Save the file as "c:\disconnect.bat" (with quotes in order to avoid double-extensions)
    Edit:
    Nevermind the autoit, I was thinking in something else. (you should be able to run the .bat file within FP)
    Thanatos.
    Nissan Aux-in MOD
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. Replies: 35
    Last Post: 08-01-2006, 11:35 AM
  3. dual wifi cards - for constant internet connection
    By neon_eddy in forum Software & Software Development
    Last Post: 09-18-2005, 01:08 AM
  4. Replies: 20
    Last Post: 11-03-2002, 06:54 AM
