Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2 small frodo problems..
  1. #11
    Nov 2004
    South West
    Thanks, I have downloaded 'Font used by skin' from
    http://frigor.frodoplayer.com/files/Fonts.zip
    Now my problem is I am stupid.
    I have un-zipped them but what now?
    Do I install them as windows fonts somehow or just copy them into the frodo directory?
    Thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
  2. #12
    Nov 2004
    South West
    Not that stupid but..
    I have installed the fonts to windows via Control Panel/Fonts/Install new..
    Now I get this..
  3. #13
    Nov 2004
    South West
    Right, I have set my DPi to 75%.
    This is working with the song info - I can see it all!
    2 probs.. 1st I can barly see the songs in the list on my 7" screen.. The text is too small espically when driving..
    2nd the skin seems to be messed up - the bottom of the mitsubishi logo is getting repeated on the top ang covering the window.. see below..
  4. #14
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I just found out what your prob is:
    you have to tick the boxes in settings 1/main info screen.... this is for long name albums,titles and artists so the name will be moving along the vis box instead of try to put all of the info in it.
    About fonts and logo you have to set you DPI to normal but even with that you may want to increase the fonts size via skin .ini
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  5. #15
    Nov 2004
    South West
    If i tick the 'scroll title' box it works (moves from left to right). But it allways did.
    I un-ticked them as i didnt like it. In full-screen it just looks like there is a lot of wasted space and a lot of empty background.
    My music is stored MEDIA/ARTIST/ALBUM/Artist-Album-Title.
    As frodo uses 2 lines (just cuts the bottom one off by half) is there no way of making the display area bigger? Reducing dpi size works but is too small to read.
    This is not (afaik) a skin issue. I get the same problem with out a skin installed.
    Thanks..
  6. #16
    Nov 2004
    Besides increasing the number for fonts in the .ini files I don't know what else to tell you...... ummm Maybe you want to make a litle test:
    Back up your skin.ini, DL the file from the thread below and overwrite the original one, then open FP and check if the fonts change or not.
    How to change scrollbar size on the ini. file
    Thanatos.
    Nissan Aux-in MOD
  1. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 01:08 PM
  2. Couple of small problems and 1 request
    By J187 in forum Road Runner
    Last Post: 08-29-2005, 07:45 AM
  3. small size Video card
    By jtk in forum General Hardware Discussion
    Last Post: 11-24-2002, 09:21 PM
  4. Interesting small PCs
    By mtmsol in forum Classified Archive
    Last Post: 04-23-2002, 12:17 PM
  5. highout, small capacity battery?
    By jshrieve in forum Power Supplies
    Last Post: 06-15-2001, 03:34 AM
