What is wrong with frodoDVD? (install Powerdvd ot windvd and you ready to go)
Thanatos.
Thanatos.
I tried frodoDVD, it is very good program, but because I have all my DVDs emulated with alcohol 120 as virtual DVD-rom i cant watch more dvds without going to windows and change emulated DVD. Would it be possible to change eject button to change to next drive and not eject the chosen DVD??
And can I get source code from frodoDVD, my friend is very good in programming and mybe he could arrange that for me?
i also tried with powerDVD, winDVD and it is still too smal for touchsreen on 7" LCD, because i must park the car and arrange it![]()
Greetings from slovenia!![]()
Did you tryed changind the drive leter in settings1/CD/DVD to see what you ca acomplish with that?
Thanatos.
settings in frodoDVD you think or in alcohol 120?
I was born brilliant, but education ruined me!
in FP. (I haven't try it but I know that you can see the letter of the emulated drive in settings 1 so al you have to find out is if draging a alcohol file to that drive is going to be play in frodoDVD)
Thanatos.
i was playing a litlle and I found out that if I eject first emulated DVD and then press play it would go to the next drive, but the first drive will be then empty and so go on while there is DVD in the drive emulated. It will help me but the problem is if you would like to go to the first DVD and if you will be on third DVD you must mount first DVD again because it will be umounted.![]()
The possible sollution is that you mount a lot of drive`s in the same order and then you will come back to first DVD and at the end of the day just mount all drive`s back.
That is for the frodoDVD in the frodo player, standalone frodoDVD will mount and unmount the same drive and won`t go ahead like frodoDVD installed in frodoplayer.
tnx thanatos106 , i will also send a developer of frodo DVD an email if he could do something about that, if he will be willing of it,because i think I am not only with that problem, i don`t like DVD player in the car, so all music DVD`s are emulated.
ya i am using CF right now but I would use frodo if it had that ability to play emulated dvds, easily as i am in the process of ripping them to my carputer
