Results 1 to 10 of 10
Thread: Problem shutting down with frodo..
    Nov 2004
    South West
    Hey guys..
    When i press the power button on my laptop it shuts down windows and turns off.
    This happens even if frodo is playing..
    Now, If i use -menu-exit-shutdown- in frodoplayer, windows shuts down then i get the 'it is now safe to turn off your computer' message.
    The laptop wont turn itself off like it does if i press power or go -start-shutdown-.
    Is there a fix for this?
    Thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    in your BIOS.. go check your ACPI settings... Mine is set to support S1&S3...
    thats all i can think of...
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Are you using take 3 or 1.10?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Nov 2004
    South West
    I am using version 1.9 take 3.
    Cant find anything like s1 or s3 in my bios settings. (pb laptop).
    Hard to see on my 700idt though so i will try and get it in the house over the weekend...
    Aug 2004
    Pearland
    is there anything to do with power settings in your BIOS ?
    Dec 2006
    Did anyone find a fix to this?
    Aug 2004
    Pearland
    Dec 2006
    thanks for the fast reply ive seen that fix but was hesitant to try. any idea if it works?
    Aug 2004
    Pearland
    it works for 90%
    Nov 2004
    South West
    I installed the motherboard drivers that came with the laptop and also downloaded and installed the latest bios.
    This improved the problem, half the time i got the message, the other 50% of the time it shut down fine.
    About a month later i chucked out the griffin power mate i was using. now it shuts down fine about 90% of the time.
    I have no idea what causes it to freeze the other 10%.
    I also had myself and 3 friends (total of 7 pc's) try it on home / work computers. It vairied between 50% and 10% failure. I.e. it locked up shutting down. Most of these were fairly new high end machines.
    Only thing was they all used the copy of frodo i had on a cd so thinking about it maybe i will just try downloading frodo again. My laptop allways (99%) shuts down ok if i use the windows option or any other program other than frodo..
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  3. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. frodo just quits on load?
    By gummybear in forum FrodoPlayer
    Last Post: 09-25-2005, 02:12 PM
