Yes there is a batch - autoit file around, also to prevent this you can use FP as a shell (check the FAQ emporium for more ditails) or you can untick "keep the task bar in top of other windows" and "lock task bar" in task bar properties.
Thanatos.
When I choose Navigation in FP it starts up like this:
And then the Iguidance window will maximize itself but it leaves the task bar below showing until I click on it manually.
Is there a way to make Iguidance look like this automatically when it starts?
Thanatos.
I couldn't find that autoit patch. I tried using skinbedder and igmod. Both will not give me a desirable result. Now FP won't embed Iguidance the same way it did before (above). Now it starts IG as an external app plus that annoying Warning window is popping up in FP and it didn't before. Please help.
I also tried reinstalling IG. And the only thing I modified in IG is the big button patcher.
Is no a autoit patch, is a batch in conjuntion with a autoit script...I will try to find it for you, but give me some time.
For the warning make a search for routislauncher for IG.
Thanatos.
Thanks, you're a great help.
