I don't think is a matter of performance, I think your specs are fine (I run 1.10 in one of my machines PIII 600 mhz without problems; also the changes on 1.10 are not that drastics for you to have a problem that you didn't have in take 31st issue:
I downloaded and tested FP 1.010 on my desktop (Atlon X2 4200+, 2Gig PC3200, Geforce 7800) and it seemed to work great, but when I put it on my WinXP, EPIA 800 mhz with 128mb PC-133, Lilliput 7" touch, it stops responding as soon as it gets on screen. Only way to get out of it is ctrl-alt-del and end process. Granted my desktop has TONS more horsepower, are my specs too low for the new FP build?
If not, any clues on why it is hanging?
So here goes my question:
Did you made a fresh install (OS + FP) or did you just installed 1.10 over your existing setup? and if so did you unregister the DLLs?
Yes the default skin tha comes with 1.10 is in fact 800x480 (brushed aluminm by febsperanza) so you have anable advance resolution settings...go FP .ini and change this line to false:2nd Issue:
My Lilliput is only capable of 800x600 and higher non 16:9 resolutionson the EPIA 800. WHen I launch FP it doesn't open full screen, it opens on the lower right quadrant, with most of the skin off screen. Since FP hangs I can't get it to move. Is the default skin with FP 800x480?
Any suggestions?
USE_ADVANCED_SCREEN_SETTINGS=TRUE
Thanatos.
LinkBack URL
About LinkBacks
