Results 1 to 4 of 4
Thread: Wrong Date in FP
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    Wrong Date in FP
    I'm running XP and FP 1.10 (the problem was also there in the prev. ver 1.09)
    When I go to work in the morning the date in FP is one day behind. For example this morning (feb. 22) it said 2-21. When i go home tonight it will have the correct date, 2-22.
    XP always shows correct date/time, with the am and the pm and all. If i turn off FP in the morning when it shows the incorrect date and turn it back on right away, it will show the correct date then, until the next morning.
    Is this a known bug? Or is there a setting that i can change? I was pretty sure FP picked up time and date from the OS.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I never seen that problem... and I'm 90% sure that FP is looking to the SYS time to display it.
    What skin are you using?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Jun 2004
    Minnesota
    I use ernie's skin
    On the way home, sure enough, it had the right date....I unchecked "sync with time server" option in the time/date preferences. Will see if that helps tomorrow.....
    Any other ideas, guys?
    Jun 2004
    Minnesota
    Well, the problem is still there. Here is what else I noticed this morning, I started embedded GPS in FP under ernie's skin. The date in the embedded window is correct (2-23), when i hit CLOSE or RETURN and go back to FrodoPlayer the date is 2-22....I'm not making this stuff up. It's weird
  1. Replies: 12
    Last Post: 03-03-2006, 09:23 AM
  2. Problem watching movies with FP & Powermate
    By maxxell in forum FP Bug Reports
    Last Post: 04-09-2005, 10:36 AM
  3. Time and Date on Menu Skin
    By phatbenny in forum FrodoPlayer
    Last Post: 12-23-2004, 08:30 AM
  4. Basic install Instructions for new FP user
    By eazyrog in forum FrodoPlayer
    Last Post: 10-13-2004, 05:04 PM
  5. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-12-2004, 11:58 PM
