bump....HELP!!!!
i searched and see that others have had the same issues, but no one seems to have a resolution.
is there a resolution for this issue....I am using wmp 9, on a 800mhz pc with 512 ram......no other programs running and frodo is between 70-90% cpu.....
it seems fine when i first start FP, but then after I change songs the first time it stays at high cpu usage....before the song change it's only like 10-15%
bump....HELP!!!!
is your wireless enabled and not connected to a network?
Didn't someone JUST make a post in an existing thread about this same thing yesterday?
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
my wireless IS connected to a network..I also took the wireless card out and the same thing was happening with the cpu usage...
What sound card are you using?
I had many USB soundcards that took up too much CPU.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
using onboard sound
you could try disconnecting all devices and see if it still happens. If it stops, then re-atach them one at a time and see if it's a device that's causing it.
also, you could run the task manager and sort by cpu usage to see if any application's cpu usage spikes when the skipping occurs.
look for the process that is using teh CPU the most in task manager...
my first set up was a P200mmx running winamp... 20 - 30% CPU usage with win2k.
TruckinMP3
Read the FAQ!
I guess i never said it in the first post, but Frodoplayer is the app that is at 80% and higher CPU usage...
