Results 1 to 10 of 10
Thread: Frodoplayer and TV
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    Frodoplayer and TV
    Hello,
    I've a Cinergy TV Card and I would like to use it Inside Frodoplayer.
    I know that I could use it as External Application with the orginal cinergy interface, but the problem is that it isn't handy and not skinnable.
    So, I would ask you if there is an external application more useful that I can use as external application inside frodoplayer...
    thank you.
    pijo
    CarPC in Progress [||||||||-] 90%
    Visit my Project
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Check my skin for info about TV plugin.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Nov 2004
    Novara - Italy
    thank you.
    I've downloaded the TVplugin and this evening I'll try it to my car.
    There is some possibility to customize the skin?
    thank you anyway,
    Luigi
    Visit my Project
    Nov 2004
    You can edit the side bars, the background, the text but no the buttons (those are hardcode in the .exe)
    Thanatos.
    Nissan Aux-in MOD
    Nov 2004
    Novara - Italy
    hello,
    I've have a little problem, I've installed FLY2000TV but when I launch the TVplugin appear a popup with "impossible to write the file setting.ini"
    could you help me to resolve the problem?
    another minor problem, after the popup has been closed, TVplugin is stil open but it's all black (probably because the setting.ini problem) and it isn't in the center of the screen, how can i move it in the center?
    thank you again.
    Visit my Project
    Nov 2004
    Novara - Italy
    hi,
    I've found the problem... tvplugin want the setting.ini file in the ...\program files\fly2000tv directory and in my case it was in ...\programmi\fly2000tv directory. I've moved the installation of fly2000tv and now it's all ok ... also the screen fitting.
    I've another little question... it's possible only to setting the volume by using the main volume, isn't it? is it not possible to control the line in volume, correct?
    bye and thank you.
    pijo
    Visit my Project
    Nov 2004
    Yes there is... check fly200 settings (open the APP and in the control panel you'll see a "settings" button) there is a option to control any of the options from the mixer.
    Thanatos.
    Nissan Aux-in MOD
    Nov 2004
    Novara - Italy
    hi,
    therefore when I increase the volume by pushing the "Volume UP" button on your TVPlugIn it wil be increase the volume of the "Master" line rather then the "Line IN" line depending on what I configured in the setting section of the FLY2000TV program, it's correct?
    bye,
    Luigi
    Visit my Project
    Nov 2004
    the Tvplugin volume will map the settings of fly2000 so in theory if you have it set to control line in it will control that (but remember that it doesn't matter what volume control you have it set if you have FP volume low it will be low too)
    Ohh and BTW is no my plugin, is dragonsBTV's.
    Thanatos.
    Nissan Aux-in MOD
    Nov 2004
    Novara - Italy
    oops... sorry...
    thank you for the information...
    bye.
    pijo
    Visit my Project
  1. XM and TV input to CarPC
    By Because in forum General Hardware Discussion
    Last Post: 05-31-2005, 10:52 PM
  2. Replies: 0
    Last Post: 02-09-2005, 07:52 PM
  3. nLite making me nSane: Frodoplayer issue
    By Nobias in forum WinNT Based
    Last Post: 01-13-2005, 01:09 AM
  4. Replies: 30
    Last Post: 10-14-2004, 01:09 PM
  5. Server/Client FrodoPlayer function?
    By Seth in forum FrodoPlayer
    Last Post: 06-23-2004, 05:20 PM
