Does anybody know where the frontend gets the track information for this calculation?
Elapsed time works fine
Remaining time counts down from 23:59:59 erratically
The status slide at the bottom of the full screen mode goes directly to the end
None of my other machines have this problem, only my CarPC
Swapped motherboards and reloaded software and the problem persists
Can anybody please help?
It will be helpful if you post:
1.FP ver.
2.Skin name.
3Maybe a pic of the problem.
Thanatos.
Thank you for the reply
fp version is 1.09 take 3 (1.10 does not work on this pc, but it does on the other machines)
I am using a skin I modified (problem persists with default skin)
Sorry I have no pictures
I would assume the frontend is supposed to subtract the elapsed time from the total track time.
The frontend appears to be subtracting the elapsed time from 24 hours rather than the total track time.
Found a thread with the same problem
Progress slider doesn't work?
the solution offered was make sure you are using wmp 9 or 10
I am, does anyone else have any ideas?
