Hi,
Can this hardware be used to add auto climate feature to non ACC cars? if yes, how easy will it be to integrate it.
sorry if you have answered this question already.
As requested the eyeR test program has been posted at the first post of this thread.
If you wish to test/modify you will need VB 2008 express edition.
If you simply want to run the program you will find the 'exe' in the 'bin/debug' folder.
Feel free to comment on any issues regarding the test software.
Hi,
Looks great. Now I really want one. How long till the release date and documentation are available?
What are the specifications for the relay outputs? I am designing a climate head replacement board (with all the protection diodes... etc) and will be selecting components for it this week, including the relays. I want to make sure whatever relays used are compatible with the EyeR outputs.
Hans
At the moment when you use the eyeR in HVAC mode it is not automatic. I have been working on automatic HVAC control software, but not finished yet as I still need to make an external sensor board. You can make auto HVAC control using VB but you will loose the auto functionality when the PC is off.
eyeR and documentation should be done by the end of the week.
The relay outputs sink to ground (400mA max, protection diodes are built in) if your just using relays to control you hvac buttons, you could get away with using small relays (12v) as opposed to the standard heavy duty automotive type.
Any relay will work as long it's a 12v type.
any progress??
If anyone gives me a rev - I give them the Bird
Yes, I have the first batch already made up and packed.. I just have to update my website with the latest products. I hope to have this all done by the end of today.![]()
could you provide a link to your site
thx
Ok, all done.
My site is almost fully updated, but enough to purchase the eyeR.
Refer to first post for link
You will be required to register just so your shipping details are recorded.
quick question before i order, does the new eyeR pro use the same micro usb cable that has been on your site, and is it already included with the pro or not?
thank you, i'm about to order today! YEAH DADDY!!!!!!
Scion xB G2
Planning: [----------]
Parts: [----------]
Install: [----------]
My Scion PC Project (put on hold until I find a nicer host):
Worklog
