Results 1 to 6 of 6
Thread: eyeR Interceptor: 25Amp PWM FET Module Add-on
    Sep 2005
    Australia
    UPDATED 27-FEB-10
    The eyeR Interceptor FET Moudule add-on is a convienient way to drive high current devices easilly and safely.
    NOW AVAILABLE
    here
    Name:  FET Module2.jpg
    Features:
    • Upto 25Amps continuous current rating
    • fully encapsulated for safety
    • Advanced FET driver stabilizing circuitry ensures the device runs super cool, even at high PWM frequency
    • 1" x 1" x 0.7" form factor! (not including mounting tabs)
    • LED status for output (LED will dim depending on output power)
    This module can be used for:
    • Variable control of heavy duty motors such as radiator fans
    • Replacing that 4-position blower switch in your HVAC system and get up to 255 blower settings
    • Hi-Speed Solid state relay control
    • Boost solenoid control
    • High current light dimmer
    The modules are available in 2 different types:
    • 25A P-type
    • 25A N-type
    So what are the differences between N-tpye and P-type?
    Say you want to control a heavy duty fan,
    If one end of the fan is permantly fixed to +V (positive) you would need a N-type module
    If one end of the fan is permantly fixed to GND (negative) you would need a P-type module
    Basically N-type sinks current and P-type sources current.
    Equivalent circuits for N-Type & P-Type respectively
    Name:  n-tpe equivalent.jpg
Size:  20.0 KBName:  P-tpe equivalent.jpg
    Related eyeR stuff: HERE
    Jun 2011
    Wellington, NZ
    What control input ?
    Excuse my noobness, but I would like to know what kind of signal is used to contol this product ?
    I have an Adaptronic E420c ECU in my car that is capable of outputing a PWM signal that varies
    with engine temperature. And I would like to know if I could control my radiator fan, using the ECU
    signal to modulate this 25Amp Add-on module ?
    Cheers... jondee86
    FKA CivicModz
    Mar 2011
    Australia
    The PWM FET module can accept a 2.5v - 15v input. So basically it can support any PWM input signal, i.e 3.3v, 5v, 12v. etc
    Jun 2011
    Wellington, NZ
    Excellent My ECU switches 12V to ground in PWM mode (12V==> solenoid==> ECU==> Ground).
    So I am assuming that if I connect the dotted line/wire to the input of the ECU, that will be
    adequate to control the FET ?? That is, if I use the P-Type module, the black wire is essentially
    replaced by the ECU ground wire ?? If so, where do I buy one
    Cheers... jondee86
    FKA CivicModz
    Mar 2011
    Australia
    Yes, connecting the dotted line/wire input to the ECU will work fine. All the work of driving the FET is done internally, so no need to worry about that. The GND wire of the FET module needs to be connected to ECU ground (Chassis).
    In regards to availability, yes that link needs to be updated!!
    I will have more ready within 1 week. I will PM you when I have more ready if you are still interested.
    Jun 2011
    Wellington, NZ
    Yep... for sure I'll take one. Just let me know when they are available.
    Thanks for your assistance
    Cheers... jondee86
  1. Replies: 0
    Last Post: 12-20-2007, 09:32 PM
  2. Intro to building DigitalMods
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 09-24-2007, 02:11 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
