1 Attachment(s)
SAY WHAT! .. InfraRed remote control add-on for your Fusion Brain!
** Now Available HERE **
When ordering you can select the IR mounting option required and also the type or IR remote you require. If you want both remotes then its a little bit extra.
Overview:
I have been wanting infrared remote control for my fusion brain for years, but couldn't work out a simple solution. My first and expensive shot at it was the 1st gen eyeR interceptor plug-in addon for the V3 fusion brain. (Yes V3, ancient now we all know!)
After many months of development of the original eyeR, the fusion brain V4 was released a few days after my plug-in mod :(. Thanks guys! :)
At that time I wasn't aware that the Fusion guys update the FB as often as their underwear. :P
The only way was to make a more "universal" way.
So what does this thing do?
This little direct plug in module for the fusion brain converts Infrared (IR) signals to analog output values so it can be directly interpreted by the fusion brain. It comes with a cable that allows you to plug this in directly into any of your fusion brains analog inputs.
You can select the mounting option you require for your particular installation
OK, now wheres that cheap TV remote I'm going to use to work with it that has buttons that do not correspond to anything?
Yeah, right....
Two custom remotes are also included for various applications.
This table shows the output voltages the device will output depending on the buttons pressed. As you will see that both remotes can work of the one board.
For example, if you press button "4" on the "OUTPUTS" remote the fusion brain will see an analog voltage of 0.4v while the button is pressed. Once you release the button the FB will see 0v at the analog input channel.
If your wondering about the accuracy of the D/A converter, its actually high speed 12bit resolution. As your probably aware, the FB inputs are only 10bit resolution. So this module can output more accurately than what the FB can actually read :)
Now your wondering... cool but my FB 4 has 5v input and my FB 6 has 3.3v input!
Not to worry, this module will work with any Fusion Brain.
