Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Practical usages of Fusion Brain?
    Feb 2006
    Hi all,
    Second thread in this new board
    I understand how Fusion Brain works and think it is a fantastic piece of hardware/software, and I even considering using it for my home automation project (which has a serious need for a device like this at this price by the way, so if the developers need some extra sales, promote it to the home automation market!).
    But I can't think of about practical usage of it in a car. It is all nice and cool being able to lock the doors and roll up/down the windows with a touchscreen... but it is not actually very useful is it, considering the hardware buttons are like right next to you...
    So any suggestions???
    Thanks.
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Well the first thing that comes to mind, for me anyways, is the truck I'm about to buy. The truck is coming with a plow that is controlled from the inside of it buy a four way lever which switched relays that control the hydraulics. That's one of the first things that this board will control once I get the truck, among other things...
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
    Mar 2006
    Colorado, but Canadian!
    Well yes the buttons will be right next to you, but that is for simple, on/off only action. The simple "press to turn on an off", will actually very a small percent of uses. That will be mostly for the aftermarket accessories that dont already have a button, and you dont want to drill a new hole in your new car.
    However, the addition of analogue input sensors, opens up a whole new world. Suppose your hvac like mine is a simple temperature selection, fan speed, and which vent. Well In the winter, you are friggin cold when you get in, so you crank it to hot and full blast, after a few minutes, then you turn it down because now you are burning. Well, if you have a temp sensor, that turns the fan to various speeds it now becomse like in the lexus rx300 or rather almost all lexus' and it controls the temp automatically.
    Dont have automatic lights like me? I personally drive with my headlights on 100% of the time, even in the middle of the day because that is just how I was raised. Safer, but I wont preach here. Anyways, I notice a lot of people just forget to turn them on even when it is dark outside. Attach a photosensor, and boom, your lights turn on when it is dark.
    For the racers around here, g-forces are important to measure for many reasons. Well hook up an accelerometer, and voila, you get results you can log and look back on any time you want all at your fingertips.
    Also you can use the brain as sort of a "macro". When you roll down your windows, you dont want your AC on, and you probably dont want your fans at such a high speed if on at all. Well the brain can do that all automatically for you.
    It is more of a "James Bond" type item, where everything can become fully automated, and regulated.
    Of course there are many many other reasons out there, but this should give you a bit of an idea of the many possibilities in the car.
    As for home automation, the relays we sell support ac voltage as well. I will be using 1 or more in my home to create a "Star Trek" type interface. That is one of the actual reasons to implement voice control. Walk into a room, and the ultrasonic sensor detects your presense, turns on the lights, and greets you. You ask "Computer, what is the temperature" and it tells you "The outside temperature is 34 degrees Celcius". "Turn on the TV. Computer, dim the lights". That sort of thing.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2006
    MA, USA
    Mar 2007
    sounds cool, but how the heck does one wire all this? Are people going to start posting howtos?
    Dec 2006
    MA, USA
    Quote Originally Posted by ironfinger View Post
    Like a lot of things it all depends on what you want to do/how complicated you want things to be... I know I document everything I do as well as most other people here. Just stay tuned and you will probably find what you are looking for, as long as you don't grow impatient and do it your self.
    Mar 2006
    Well we are incouraging people to take pictures of their implementations of the Brain, and hopefully some people will put together a Howto or mini-FAQ collection specific to the Fusion line of products right here. I will also mirror them on our website under Help/FAQ. Of course that works both ways too. Once something goes up there, it will go in here as well.
    I think I will put another subcategory for FAQ's or Installation How-To's. Thoughts on that?
    And for the lucky people who have their product already, we can do a sort of "ThinkGeek" style thing, where we can have a user-photo section. That could bring some interesting results.
    Dec 2006
    MA, USA
    Quote Originally Posted by 2k1Toaster View Post
    That sounds good, I know Id contribute to it... how about hacks as well for those of us who have already started hacking our
    I like that as well... ditto above
    Mar 2007
    sounds good. I'm sure tons of people are interested in this product but, just like me, have no clue how it actually works... a wiring example, such as window control, or turning on/off amplifiers should help a lot.
    Mar 2006
    Well we will get working on this then. Right now I am about 50% done my partner program to the main Fusion Control Centre application that I think people will enjoy. Then I have to document the massive program, and Tim will be working to document all the Hardware. Then we will get to install how-tos. The more photos the better, so to those with the Brain already, get that camera ready!
  1. Brightness of 300 vs 350 nits - Practical difference?
    By jasonsjwou in forum LCD/Display
    Last Post: 11-24-2006, 12:54 PM
  2. Found this interesting site - covers FB work
    By kingtut in forum Fabrication
    Last Post: 12-07-2004, 03:36 PM
  3. practical mechanics?
    By Walleye in forum Off Topic
    Last Post: 09-28-2004, 04:17 PM
  4. Not exactly Practical, but damn, very cool
    By bombboyer in forum General Hardware Discussion
    Last Post: 09-01-2002, 04:12 AM
