That wouldn't be a problem at all, you'd need the brain and one relay.
im still a little sketchy on exactly what can be done with the fusion brain hardware but what i wanted to know is if it was possible attatch the remote turn on/off for an amp to the fusion brain hardware so it would turn on the amp after the computer had booted..therefore eliminated the "thump" problem?
I wish i knew how to do fiberglass work...
1.9in x 2.9in -- 47mm x 73mm
sweet.. this is reason enough for me to get one
could i just hook up the the remote turn on wire directly to the fusion brain and go to the amp.. or do i have to use a relay method to do it.
Its not that much of a big issue but it would make it a bit easier of an install..
thanks.
Not trying to discourage fb, but why spend the time and extra money when there is a plug and play device on the market that does this for you? If thats all your interested in take a look here.
http://www.autosound2000.com/amp.htm
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
That still only works off of guessing. It uses a fixed time. Some 2.5s some from 0-30. Computers dont boot the same every time. If you have bhigh end components that are sensitive to pops, or are in competitions where pops are an absolute no-no, then the Fusion Brain is perfect.
The FB wont just guess. It will wait until windows has loaded, meaning 100% that audio drivers are loaded. No guessing needed and perfect 100% of the time.![]()
yes, i suppose. I have been using that 0-30 second one for the last year and have not heard a pop since. If I was to restart my computer for some reason while driving, the pop will be heard.
well and the fact that you can do a whole lot more than delay turn on of amp for only $25 more
