Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 68
Thread: set up and use questions
  1. #11
    Mar 2007
    manchester, UK
    p.s. it must be something in the skin settings (as apposed to winamp/the commands), because if i switch the UP and DOWN over the down works but not the up.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    #ENABLEHIGHSWITCH#true
    #ENABLELOWSWITCH#true
    #LOWKEYSEQUENCE#DOWN
    #HIGHKEYSEQUENCE#UP
    #LOWMAINWINDOWTITLE#winamp
    #HIGHMAINWINDOWTITLE#winamp
    #HIGHTHRESHHOLD#d0.06
    #LOWTHRESHHOLD#d0.06
    That is why. If the volume changes by +0.06, the volume will go up. If the volume changes by +0.06 the volume will go down. Since it sees this as an error, it wont evaluate the latter one. It should be negative... Not at my developing computer right now, but I believe it should be ...#d-0.06. If not try ...#-d0.06.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Mar 2007
    manchester, UK
    cheers, got it in the end. it id d-0.06 not -d0.06.
    thanks.
    now how do i get my digital switches to do "next track?"
  4. #14
    Mar 2006
    Quote Originally Posted by wilgartw View Post
    thanks.
    same thing under digital inputs, except change the key sequence to the correct key function...
  5. #15
    Mar 2007
    manchester, UK
    sorry for this... and thanks for your patience
    i've done this
    >>DI_INPUTS
    #STARTNEW#
    #NAME#next track
    #KEYSEQUENCE#nexttrack
    #MAINWINDOWTITLE#winamp
    #SUBWINDOWTITLE#
    #SUBCLASS#
    #PORT#0
    #MINTIMEBETWEEN#100
    #VIDPID#vid_04d8&pid_000c
    #ENDNEW#
    <<END
    i am using the blue ports nearest the corner,
    i've tried next, next track, nexttrack,next_track.
    if there is any documentation please point me towards it (and i'll stop bugging you).
  6. #16
    Mar 2006
    i've done this
    I am making the documentation now, and so far it only covers the digital outputs. It will be here in about a week probably: http://www.fusioncontrolcentre.com/F...php?tutorial=3
    And "Key sequence" needs to be just that. A Key sequence. Right now the equivalent is if Winamp was open and you pressed "n", "e", "x", "t", "_", "t", "r", ""a", "c", and "k".
    You need to look at the winamp keyboard shortcuts: http://www.accesstechnologyinstitute...rds/winamp.htm
    and then keysequence for next would be "B". That simple.
  7. #17
    Mar 2007
    manchester, UK
    AH Thanks,
    i had tried 'B' but it didn't work. but now i am trying it that doesn't work when i am in winamp either.
    i will keep trying!
  8. #18
    Mar 2006
    Well they may have changed the keystrokes depending on the version.
  9. #19
    Mar 2007
    manchester, UK
    my keyboard didn't work because of my nvidea graphics card software. I've disabled that but i am still unable to get it to send the keystroke.
    i will wait until your instructions are out next week.
  10. #20
    Mar 2006
    Well if you have winamp open and you press keys on the keyboard, does it work?
