Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 68
Thread: set up and use questions
  1. #21
    Mar 2007
    manchester, UK
    it does now i have switched off the graphic card's software.
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by wilgartw View Post
    Well what are your skin settings. Are you using the designer, or are you copying and pasting in Notepad?
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Mar 2007
    manchester, UK
    i've tried both.
    they are currently:
    >>MAIN
    #TILESTRETCHBACKIMAGE#STRETCH
    #SIZE#640;480
    #ANIMATIONINTERVAL#100
    #ANALOGUEINTERVAL#40
    #SYSTEMTRAY#false
    #USESPEECHRECOGNITION#false
    #USESPEECHFULLDICTATION#false
    #SHOWMENUBAR#true
    <<END
    >>OUTPUTS
    <<END
    >>AI_INPUTS
    #STARTNEW#
    #NAME#volume
    #TYPE#POTENTIOMETER
    #SUFFIX#voltsw
    #PREFIX#
    #SETTINGS#
    #VIDPID#vid_04d8&pid_000c
    #SIZE#300,250
    #LOCATION#0,0
    #ENABLEROTATEMAINS#false
    #SHOWTEXT#true
    #SHOWTEXTVALUE#true
    #PAGE#0
    #DECIMALS#3
    #PORT#0
    #TXTCOLOUR#White
    #BORDERSIZE#0
    #FONT#Arial;6.75;Regular
    #PLOTLENGTH#100
    #ENABLEHIGHSWITCH#true
    #ENABLELOWSWITCH#true
    #LOWKEYSEQUENCE#UP
    #HIGHKEYSEQUENCE#DOWN
    #LOWMAINCLASS#
    #LOWMAINWINDOWTITLE#winamp
    #LOWSUBCLASS#
    #LOWSUBWINDOWTITLE#
    #HIGHMAINCLASS#
    #HIGHMAINCLASS#
    #HIGHMAINWINDOWTITLE#winamp
    #HIGHSUBCLASS#
    #HIGHSUBWINDOWTITLE#
    #HIGHTHRESHHOLD#d0.07
    #LOWTHRESHHOLD#d-0.07
    #ENDNEW#
    <<END
    >>DI_INPUTS
    #STARTNEW#
    #NAME#next
    #KEYSEQUENCE#B
    #MAINWINDOWTITLE#winamp
    #SUBWINDOWTITLE#main window
    #SUBCLASS#
    #PORT#0
    #MINTIMEBETWEEN#10
    #ENDNEW#
    <<END
    >>OTHERBUTTONS
    <<END
    >>DEAD
    <<END
    note that when i use the skin designer and add a digital input, it adds:
    #LOWMAINCLASS#
    #LOWSUBCLASS#
    #LOWSUBWINDOWTITLE#
    #HIGHMAINCLASS#
    #HIGHMAINCLASS#
    #HIGHSUBCLASS#
    to my analogue input and stops it from working.
  4. #24
    Mar 2005
    How are you connecting the digital switch?
  5. #25
    Mar 2007
    manchester, UK
    with a "push to make" switch.
    is there any way of seeing a reading like the analogue switches?
  6. #26
    Mar 2006
    subwindowtitle should not have anything there.
    Do not fill those in unless you know what they are. These are not the titles given that you can see. These are the titles given by Windows at the system low level. For instance, I only programmed winamp in there because it would be used very often.
    It should actually be "Winamp v1.x" for the class and the title/subtitle/subclass need to be null. And for Internet Explorer 6, it doesnt include those words at all. You need to use a program such as Spy++ to get the window handle at a minimum and the full title/class subclass/subtitle would be best. I have already programmed in Winamp.
    There is no such subclass as "main window", so it errors out. You cant just randonly add stuff and expect it to work....
  7. #27
    Mar 2007
    manchester, UK
    ok, i tried it without that first and it didn't work (I will give it another go in a minute when i have rebooted.)
  8. #28
    Mar 2007
    manchester, UK
    >>DI_INPUTS
    #STARTNEW#
    #NAME#next
    #KEYSEQUENCE#B
    #SUBWINDOWTITLE#
    #SUBCLASS#
    #PORT#0
    #MINTIMEBETWEEN#10
    #ENDNEW#
    <<END
    is my current config, but it definately isn't working
  9. #29
    Mar 2005
    so the inputs work for play/pause, but not skipping tracks?
  10. #30
    Mar 2007
    manchester, UK
    no, i do not seem to be able to get any of the digital inputs to work.
    is there any quick way of testing them?
