Page 7 of 7 FirstFirst 1234567
Results 61 to 68 of 68
Thread: set up and use questions
  1. #61
    Mar 2007
    manchester, UK
    Quote Originally Posted by wilgartw View Post
    hello i know you are busy with the vista bit ( an i am looking forward to using the product through an usb hub). however i still connot get it to send a next track "B" key to winamp. do you have a skin where this actually works?
    from memory my issues last summer were
    not being able to FFWD a track in winamp (mimicking right arrow, or keyboard B)
    Being able to control windows volume
    not being able to feed the USB through a Hub
    i am keen to pick this up in the next couple of weeks.
    wil
  2. #62
    Fusion Brain Creator
    Mar 2005
    I can answer some of this.
    I think FFWD works, PM Nick to double check.
    I don't think windows volume works, check with Nick.
    USB through a hub does work. It needs to be a good quality USB 2.0 hub.
  3. #63
    Mar 2006
    Colorado, but Canadian!
    Yes send keys work in both Version 2 and MDX.
    In both cases the "key" for the right arrow is "RIGHT". And on the same note, down is "DOWN" up is "UP" and left is "LEFT". For single keys, it is just the key "a" or "b" or "c" or whatever.
    Window's Volume is tricky. I havent been able to find any examples to go off of. I found 1 that uses the windows media player library but it only controls the wave line and it lags (like a half second lag between sending the command and receiving confirmation it worked). I have this on the list.
    But I have COM working almost compeltely now, so that means you will be able to control the FB through RoadRunner which in turn can control the windows volume directly. I hope this to be out this week as well. I am so close I can taste it!
    1.9in x 2.9in -- 47mm x 73mm
  4. #64
    Mar 2007
    manchester, UK
    Quote Originally Posted by 2k1Toaster View Post
    cheers, what is mdx? any tutorials?
    should i go for version 2 or mdx?
  5. #65
    Mar 2006
    Tutorials in general: http://www.mp3car.com/vbulletin/docu...ion-tutorials/
    MDX Download and Common Install Errors: http://www.mp3car.com/vbulletin/docu...rsion-mdx.html
    MDX Configurator: http://www.mp3car.com/vbulletin/soft...a-testing.html
    In the config you cannot open files currently, or setup graphics. But FB detection, Digital Outputs, Analogue Inputs, logic section, variables, log files, and everything else is setup and working 100%. You can however save files. So if you do it all without closing the editor you are fine. Obviously opening a file is what the open button is there for and will work once it is official which I hope is very very soon.
  6. #66
    Mar 2007
    manchester, UK
    how soon, is very soon. I want to do abit of work on this, but not if i can't save it.
  7. #67
    Mar 2006
    Has been available for a week or more now.
  8. #68
    Mar 2007
    manchester, UK
    that'll teach me post without reading all the other threads...
    sorry!
