Page 1 of 7 1234567 LastLast
Results 1 to 10 of 68
Thread: set up and use questions
    Mar 2007
    manchester, UK
    i have recieved my kit. but now i am a little bit lost as to what to do.
    if i run the exe, it requires a skin. so i renamed and moved the FusionFormDynamicBMV2withTemperature.skinplug
    I can see that the temperature sensor works if i it into analogue port 1.
    however my first project is to control winamp.
    I have a potentiometer that i want to use to control the volume, and i have four push to make switched that i would like to control "previous track","pause", "next track", and something else (probably).
    what do i need to do in order to do this?
    Mar 2007
    manchester, UK
    ok did a bit (a lot) more reading tonight and i have now had a play with the skin editor / configurator programme.
    I have hooked up my potentiometer, and i have got my skin reading from 4.98 when the "volume is turned down" and 0.00 when the "volume is turned up".
    so now i just need to know how to control winamp's / master volume with this.
    any pointers?
    Mar 2006
    Colorado, but Canadian!
    In the analogue configuration page of the skin editor, select the "dx" box which means incremental steps, and enter the step value. If you have it set to 0.1, then everytime the voltage changes by 0.1v, it will send the keystrokes to the window that has the correct title and class.
    I made it so that, if the title is "winamp", it will automatically fill in the other info. So set to 'send keystroke' and then make "title" to be winamp. Set the key to the keyboard shortcut to what you want. Then it will send keystrokes through the API (meaning not to the focussed window, but to the window you specified which is important) and it will work.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    manchester, UK
    thanks for that i'll give it a go when i get home from work.
    i don't suppose it can control the master (windows) volume?
    Mar 2006
    Quote Originally Posted by wilgartw View Post
    Not at the moment but it is on the list.
    Jul 2007
    Damn, do you ever sleep?
    Mar 2006
    Quote Originally Posted by kostyanj View Post
    Nope.
    I work on this project for many hours a day and night, and then I have 2 jobs and then university again in a few weeks. I am a busy person.
    Mar 2007
    manchester, UK
    ok, done all that but no joy.
    here is my "skin"
    >>MAIN
    #TILESTRETCHBACKIMAGE#STRETCH
    #SIZE#640;480
    #ANIMATIONINTERVAL#100
    #ANALOGUEINTERVAL#40
    #SYSTEMTRAY#false
    #USESPEECHRECOGNITION#false
    #USESPEECHFULLDICTATION#false
    #SHOWMENUBAR#true
    <<END
    >>OUTPUTS
    <<END
    >>AI_INPUTS
    #STARTNEW#
    #NAME#volume
    #TYPE#POTENTIOMETER
    #SUFFIX#voltsw
    #PREFIX#
    #SETTINGS#
    #VIDPID#vid_04d8&pid_000c
    #SIZE#300,250
    #LOCATION#0,0
    #ENABLEROTATEMAINS#false
    #SHOWTEXT#true
    #SHOWTEXTVALUE#true
    #PAGE#0
    #DECIMALS#3
    #PORT#0
    #TXTCOLOUR#White
    #BORDERSIZE#0
    #FONT#Arial;12;Regular
    #PLOTLENGTH#100
    #ENABLEHIGHSWITCH#true
    #ENABLELOWSWITCH#true
    #LOWKEYSEQUENCE#
    #HIGHKEYSEQUENCE#
    #LOWMAINWINDOWTITLE#winamp
    #HIGHMAINWINDOWTITLE#winamp
    #HIGHTHRESHHOLD#d0.1
    #LOWTHRESHHOLD#d0.1
    #ENDNEW#
    <<END
    >>DI_INPUTS
    <<END
    >>OTHERBUTTONS
    <<END
    >>DEAD
    <<END
    **SKIN FILE COMPILED BY FUSION CONTROL CENTRE SKIN DESIGNER BETA**
    ** www.FusionControlCentre.com **
    what have i done wrong?
    Mar 2006
    #LOWKEYSEQUENCE#
    #HIGHKEYSEQUENCE#
    Those need to actually have something by them.
    What key do you want to send? "UP" is the up arrow and "DOWN" is the down arrow for volume by the way.
    Mar 2007
    manchester, UK
    ok, done that
    #LOWKEYSEQUENCE#DOWN
    #HIGHKEYSEQUENCE#UP
    #HIGHTHRESHHOLD#d0.06
    #LOWTHRESHHOLD#d0.06
    the Up volume now works, but not the down?
    any ideas?
