Okay, I finally got a chance to get the values. I got out my multimeter and I set it to 200 V~ because that was the only one that gave me numbers that looked right. Hopefully these numbers are the correct ones.
Another thing I noticed was that the number seemed to go up from the moment I pressed it until the time I held it for a second or two. I'm not sure if my multimeter just isn't fast enough or if there is a difference from pressing the button and actually holding the button.
Anyway, these are the numbers I got when I held them till they stopped changing.
preset .5
am/fm 1.3
seek dwn 2.1
seek up 2.9
mute 3.8
play 4.6
vol dwn 5.5
vol up 6.5
This means my highest value is 6.5. Thanks for working with me, I'm really excited about this. It looks like you helped Voltan through this process as well. I'm going to use the new version of the
software that uses the xml file. It looks like I should be able to modify his code with my numbers. He's using centrafuse, but I'm using roadrunner.
I noticed through the thread the most complicated thing was the voltage divider. It looks like I just need to put the correct resistors in the correct place and it should spit out values that are under 5v which the brain can accept. Does that
sound right?
I'll go get the resistors tonight if I know what to get.
