HAHAHAHAHAHAHAHA!!
That's amazing.
1.9in x 2.9in -- 47mm x 73mm
Ok, the newest release of software is Beta again because of all the changes and I havent tested as thoroghly as I have the others. I havent had anybody tell me they have had problems, so that is good.
So 4 of the features are now available.
By using an analogue input, with a button using the +5v and v_in pins (top and bottom), you can now either toggle the output everytime the button is pressed, or have the output only on or off while the button is pressed.
I have also unlocked the debug screen. In the program click about 3 pixels from the top menu bar a few times. Then hold the left ALT+SHIFT+CTRL while then typing "DEBUG". A little window should popup. Type in "open raw debug" and you should get a window that shows all sorts of stuff.
And of course the biggun, is that it works on Vista and XP now. The install is pretty different for the driver though.
Could you make a plugin to show info directly in Centrafuse frontend?
Wow, you really buried that debug window.
And there are quite a few other commands as well. I dont think they really do anything useful for the majority of users.
Should this be in the software section. Sorry I didn't see this one earlier, I've been all over the place with my questions.
What about a third image. Right now the only way I can see disabling a button is by making it dissapear, by moving to a similar screen where it doesn't exist. An enabled button and perhaps a third image could give this affect. Just one example that could pull this all together would be a sunroof control. When the car is above say around 25 mph we don't want the sunroof to be able to move. We've become so accustomed to letting disabled icons let us know that the sequencing is wrong or the 'interlock' hasn't been met with our PC's today; I think it would help to make use more intuitive. As far as an input trigger or other button controlling this new enabled property, I'm not sure how without making writing a skin more like programming software.
I'd hate to take another chunk of time off of my project to learn a new programming language like C#, but I'd rather be contributing to this than begging for new stuff all of the time.
It's been a while...
