Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 105
Thread: Fusion Brain Software Feature Requests [VERSION 2]
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Ok updated the big list up top.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mar 2006
    Updated the big list.
    You can now have multiple background images. One per page. Change a page, change the background!
    It is still declared in the "MAIN" section, buit now "#BACKIMAGE#ImagePath" is "#BACKIMAGE#ImagePath|PageNumber"
  3. #23
    Mar 2006
    Ive finally had some time these past few days to work on the software more.
    I have gotten the beginnings of controlling the wave volume directly. It seems to work as I expected. I havent tested on XP, but it should control the wave volume directly. On vista it is sort of odd, but that is to be expected because of the new system mixer...
    I also fixed the log files and a few others. I hope to get this volume working and release another update!
  4. #24
    Oct 2006
    Las Vegas
    On an analog in; when specifying a size for a the 'button' or graph image, the image used is resized to fit the specified constraints of the size property.
    But on a digital out, which appears to be coded the same way (except for the variable it's assigned to) all of the way up to windows.forms.control size, the button's image is cropped if the specified size for that property is too small. I just don't see why they would act different but they do. Granted I'm just starting to take a look at the code, and I'm not a very good programmer (especially c#). But I tried to help.
    The feature I would like is that the digital outputs resize in the same way analog in does.
    It's been a while...
  5. #25
    Oct 2006
    Las Vegas
    Funniest thing happened to me on my way to my favorite sub-forum today... I tried to take a screenshot of the Fusion Control Center program and it turned invisible for the picture. Appearantly Nick coded some special vampire property right into the software. Now that's what he must have meant with the doom thing. Also, did you intend for us not to be able to screen capture it? Maybe it's paint shop pro, but that program has been a flawless screen capturer for me until now.
    It's going to be hard to explain this without showing it, but, the 10th Digital output button I have created has a problem with the Y component of the #LOCATION# property. No matter what location I put it in, it goes vertically centered on the screen. Here's a link to a .rar of my file, showing my problem(2.7M), since I can't show it in here.
    The feature I would like, is obvious.
  6. #26
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Alright I will look into that.
    Nope no vampire coding lol. The program still displayed but didnt write to the capture buffer? Did it just show up black where it was supposed to be, or did it just show through to the desktop? I havent changed a thing as far as that goes. Maybe your program is cursed?!
    Ok, I will look at that now.
    The ability for it to cook you some tacos automatically?!
  7. #27
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    No black frame, nothing showed at all, it's like I closed the window, but... ok here's the pic:
    Scary huh? Notice how FCC looks open down below. It's not something that is going to matter in the big scheme of things, it's just going to make screenshots and troubleshooting that way hard.
    I also noticed with that 10th button, vent, it has a clickable area larger than I specified on that skin in the rar. I'm not sure why that's happening either. it's like the vent button is in the lower right hand corner of a 4x larger button.... It is right above an anolg input bar graph that I have that is not visible. That might be part of it too.
  8. #28
    Mar 2006
    OK, it is a syntax error. Look closely...
    You have no #ENDNEW# after the output. So it is reading in the location from the first analogue input, which is in the middle. And that first analogue input is not being read in at all.
  9. #29
    Oct 2006
    Las Vegas
    I even looked up and down, trying to make sure I wasn't going to make myself look dumb.... Oh well. Sorry to waste your time. I'll be more careful proofreading before I post, next. But that antilink thing, I'm not sure now, I better take another careful look. It seems to work just like link though.
    "! I always forget to carry the one or some minute detail..."
    "This isnt some minute detail Michael!" - Office SPace
  10. #30
    Mar 2006
    Its like in Superman III.
    Its no problem, I make stupid mistakes as well. First glance I missed it. I have the ability to open it and go line by line through the debugger and watch the local variables as they are parsed in. When the location call was brought up 2 times without a break inbetween I knew something was up.
  1. Feature Requests
    By frodobaggins in forum PowerVoice
    Last Post: 02-20-2006, 03:03 AM
  2. Feature Requests
    By 0l33l in forum GammaControl
    Last Post: 01-22-2006, 07:46 PM
  3. Feature Requests
    By 0l33l in forum SkinBedder
    Last Post: 09-03-2005, 03:16 PM
  4. Feature Requests
    By Nic in forum NeoCar Media Center
    Last Post: 11-11-2004, 06:27 PM
  5. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
