Or I suppose, to put a different angle on it, I could connect both the F/B and the Velleman Remote Reciever to the relays??
Trouble is, would the F/B notice the change of state of one of the things connected up if used the remote control?
For example, if I had the interior light connected to the F/B and the remote, and then turned it on with the remote, would the Fusion Brain notice that the light has been turned on? Or would it simply just change the state of the relay when I clicked the button in the control centre? For example it was on with the remote, and then I turned it "on" with the f/b, it would actually turn it off?
I suppose a possible solution to this is use buttons in the skin that don't tell you whether its on or off, its just a graphic you click on, which remains the same whether the relay is on or off. But don't know whether this would work?
I would appreciate your comments on this, as I don't know enough about it.
Cheers.
LinkBack URL
About LinkBacks
