Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Integration of factory oem buttons
  1. #11
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by 2k1Toaster View Post
    You can actually use 127 of them at the same time now.
  2. #12
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by durwood View Post
    I've already done the volume by tapping into a mousewheel and using autohotkey to change volume in roadrunner, but if this would do everythign in one shot I'd be extremely happy.
    Ok that is probably the problem I have with my current setup. I don't know what the clock rate is for a mouse, but between the rotary encoder, autohotkey and RR, the delay is quite large, at least larger than is desired.
    I was doing this with a mousewheel and girder, and yes, there was a lag time, and not a instant event the way it should be.
    Cool. I was looking at picking up a powermate and itnerfacing with that but that might be another option.
    I personally would not recomend one of those. I started out with one and had problems once or twice a week coming out of standby and having no vol control(had to unplug and replug to get vol ctrl back)...so I ditched the idea. Now, it's just a expensive paperweight!
    As far as my current volume control situation, If I turn the knob fast, the volume doesn't increase that fast but it will ramp up after I'm done turning. I guess that is just becuase autohotkey is simulating keystrokes and it takes it little bit to "catch up". It can really catch you off guard if you aren't careful.
    My final solution to this whole problem was to use girder and have it directly control the audio lines, which act just like a reg head unit, 85% instant change!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #13
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Might this thread be of some use?
    Steering Wheel Controls
    I don't think it's quite what you're looking for, but it may give you some ideas.
    Leonardo Da Vinci
  1. 2006 Acura TL OEM Navi Touchscreen Integration
    By met152 in forum Show off your project
    Last Post: 09-24-2010, 11:34 PM
  2. How-To: Relocating Screen Buttons
    By Altimat in forum Fabrication
    Last Post: 11-07-2007, 04:48 PM
  3. Custom Install of 7" into 350Z - looks OEM
    By BLK_GTR in forum Fabrication
    Last Post: 01-29-2007, 03:18 PM
  4. Where to get black Lilliput buttons
    By Quattro in forum LCD/Display
    Last Post: 09-14-2004, 08:49 PM
  5. Where To Buy Buttons, Switches, Lights?
    By eCarô in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:25 PM
