Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: ** NEW Software, Skin Designer, Drivers (XP & Vista Compatible & Faster!!!)
  1. #21
    Oct 2006
    Las Vegas
    I'll try what you say in a few before I ship it off, but I already tried all of my ports, and 2 different computers. I used the 2.0 drivers, and always had that error.
  2. #22
    Feb 2006
    Melbourne, Australia
    Just remember to uninstall it from device manager, and then restart pc with the device connected.
    Once in windows, unplug/re-connect and it should pick it up and ask for a driver location.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  3. #23
    Mar 2006
    Colorado, but Canadian!
    Your Vista machine needed the ClassInstall32? That is very odd...
    What version of Vista are you running, and are you an early adopter (like 2006-spring2007)?
    1.9in x 2.9in -- 47mm x 73mm
  4. #24
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Sounds like the problem I had man..
    PLug it in to usb, then S L O W L Y plug in the power plug to the brain. Stop pushing it in further as soon as it powers on. Try plugging it in super fast, and super slow. This is what was causing issues with mine..
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  5. #25
    Oct 2004
    NY
    sounds like a switch should be used then instead of plugging & unplugging, I guess it doesn't like the electrical noise of the barrel sliding on the contact...
  6. #26
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Thats what I was thinking, but it has buffering caps both before and after the regulator i believe.. shouldnt really matter
  7. #27
    Mar 2006
    I plug and unplug all the time. I have done this even as the stream is being read/sent to test what happens if the pc fails, and it has never had any issues. I am using the AC-DC adapter from my screen which puts out 1A at 12vdc. It is a clean signal for a chinese ripoff monitor. Perhaps your converter is just very noisy? What are you using to power it?
  8. #28
    Oct 2004
    NY
    I never had an issue with mine either... maybe the power supply is shakey or the barrel connector isn't 100%? oh, but come to think of it I soldered mine anyway
  9. #29
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    I was using the power adaptor for my travala case.. It could be that, it could be the 220v diesel generator =p
    It's been awhile since I played with it.. It will get more use and testing, and probably a companion brain, when I get home in 6 months and do my install =]
  10. #30
    Oct 2004
    NY
    sometimes the plugs are close, but too loose, there are so many variations of the barrel connectors & sometimes more than one will work, but not tight enough...
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  2. Parallel LCD with XP software
    By gavinzbitz in forum LCD/Display
    Last Post: 10-15-2003, 12:44 PM
  3. Code my own XP touchscreen drivers?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 09-17-2003, 05:11 PM
  4. Power DVD XP skin
    By cproaudio in forum Software & Software Development
    Last Post: 01-19-2003, 01:35 AM
