No directx needed at all. Are you running off of a nlited system or something?
.NET update should install everything you need.
i was thinking maybe direct x?
1.9in x 2.9in -- 47mm x 73mm
was .net that was giving me greif..! now im ready to roll. lets get cracking on the uber software.. and some tutorials on whats what.. lolim eager to control my relays based off what the air pressure senders are doing..
one more thing..
with the relays, there is four prongs on them on one side were you guys have soldered onto, can i run a led through that other side so when its in operation the led is on? is that why they are there?
No. You can connect an LED in parallel to the wires soldered on there, but make sure it is a 12v LED because those leads are 12v.
sweet deal. thaNKS
