I know, we are never satisfied, however nifty the device, but here is a request. I would like to monitor engine temp, trans temp, and other temperatures and pressures that require robust screw in sensors that screw into some kind of fluid such as coolant or oil. GM makes thermister sensors that they use in many many applications, which are very reliable and robust and proven, but they are not linear. Similarly there are pressure sensors available that are non linear. Can you set up the fusion so that it can give a read out based on a look up table of observed voltage vs. displayed temperature/pressure?
A second request would be to
sound an alarm should the temperature or pressure or whatever exceed a given level. This could be done through one of the digital outputs, at the same time the appropriate input flashes or does something to identify which input is the problem. If I understand some of the other posts correctly, you may already be able to do this.
Regards, Druber
