Results 1 to 10 of 12
Thread: Few Questions and a background for a skin
    Oct 2007
    Hello, i have been following this project for two months now, and im about ready to participate. heres my vision. I am going to remove my speedometer and tachometer from my project car (BMW E21) and replace them with one 7 inch screen. I am going to keep some physical gauges as they are extremely vital (eg: Fuel Level, Coolant Level, AFR, and Oil Pressure) all the others (eg: Boost, Oil Temp, Tach, Fuel Pressire, EGT, Pre and Post IC temps, and Air To Water Intercooler Reservoir water temp) will be displayed on the screen, i will use the fusion brain to do this and some other neat things. For example, i will have a CO2 Spray bar on the Heat exchanger for the Air to Water Intercooler and if the reservoir temperature gets to high and the throttle is at WOT then i want the Fusion Brain to Open the Solenoid and spray -80 degree CO2 on the heat exchanger and cool off the water.
    so heres waht i need, i need to find the easyest way to get these temp and pressure sensors to work with the fusion brain. also i need to see how i can get it to display RPM's, i really just need RPM's for when i want to drive economically as i will have 2 F1 style sequential shift lights that tell me when to shift when im racing.
    i have tried to design a skin and its pretty straight forward, ive attached the background image that i designed in like 10 minutes, hopefully i can submit two complete skins and $25+$25 = $50 i can get my fusion brain for shipping cost.
    Please help me out i need to know the easyest way to go about connecting all of these analog signals. and the pulse signal from the tach.
    thanks
    Mar 2006
    Colorado, but Canadian!
    For the pulse signal, you need a frequency to voltage converter. That then feeds into the Brain, which displays it on the PC.
    For temperature and pressure sensors you already have, they are probably resistive. So you will need a voltage divider.
    Sounds like a cool project!
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2007
    i just realized the background was the first one i ever made, it was completely off center and sized incorrectly. heres a much better one with digital readout boxes aswell.
    Nov 2006
    2k1Toaster, can you check your pm's
    Jul 2005
    keep this post updated? i want to do very similiar things.. i want to at least extract the rpms and speed from my tacho
    Mar 2006
    Quote Originally Posted by Sp0tteh View Post
    Replied.
    Oct 2007
    yeah ill keep this updated. i have a question for you 2ktoaster, i want to use a custom "seven segment LED" font for the numbers but it refuses to work. whats up with that? also i want to submit my skin for your contest. is it ok that all of the values for the gauges are set to default, i think that because everyones sensors may be different if i leave the values at default people can just go in and insert there own. also how many entries have you recieved? thanks
    Mar 2006
    Quote Originally Posted by killerkiko View Post
    The font must be registered as a font in windows. If it is is will show up in the skin designer in the list. If it does not show up, then the font is not installed correctly. If it is showing up in the skin designer list, but not in the main program, then let me know and I will look into it further. I never change fonts so I havent tested that extremely thoroughly using custom fonts, only pre-installed fonts.
    And we havent really received any skins as entrants. Everyone has been making their own and not wanting to share or they just dont know about it. I dont know whats up, but you are welcome to enter. I am going to pick the winner probably early december, so whoever wins can get it ordered for the winter break time.
    And yes the values can be default. that is fine. Just make sure the skin is readable!
    Oct 2007
    yes the font is registerd in windows, but it still doesnt come up.
    Mar 2006
    Come up in the skin designer or in the main program?
