Results 1 to 9 of 9
Thread: How to Open Debug Console and Raw Window for Fusion Brain
    Mar 2006
    Colorado, but Canadian!
    I have unlocked the debug screen in the main program so that you guys can see the inner workings of the program. If something isnt quite working as you expected, then this is the first thing to check. Make sure you are getting data back! This was mentioned in a thread but sort of burried. I have been PMed a few times asking about it, so I thought I would make it more obvious!
    To open the Debug Console, in the main program click about 3 pixels from the top menu bar a few times. Then hold the left ALT+SHIFT+CTRL while then typing "DEBUG". A little window should popup. Type in "open raw debug" and you should get a window that shows all sorts of stuff.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Las Vegas
    So, within the raw debug screen, how do I acutally change say 0x0 value, I've clicked on everything and nothing is happening... right clicking gives some options with unicode characters, but I don't think that's what I would have to do, but ...I don't know. I'm trying to simulate a voltage on one port. That should be all I need to do. digital in would be nice eventually but not right now, hopefully I'll get a working brain soon.
    It's been a while...
    Mar 2006
    open the debug console.
    then type in "set a0 3.3" and analogue port 0 will be set to 3.3v
    Oct 2006
    Las Vegas
    I get a bad Pin index error when I do that, or any voltage.
    Edit: I had an error in an analog in #MULTILEVELGRAPHICS# (bad file name) which fixes other problems I was having, and this as well.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    command failed miserably.
    Mar 2006
    Ok, so it is working now right? Obviously the index had to exist, or else it would fail as it did.
    And I like adding some personality into my programs
    Oct 2006
    Las Vegas
    Yeah it works like a champ. Now about that skin editor...(next thread please)
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Yeah the skin editor is pretty buggy right now. I edit all the skins in Notepad. I have been trying to fix some of the errors in the designer right now, but it was the first time I did controls that spawned themselves, and well, there are a few bugs to say the least .
    Notepad works though.
    Oct 2006
    Las Vegas
    That's what I'm using. And I have to say thanks again for all of your efforts.
