Results 1 to 5 of 5
Thread: Ordering Fusion Brain Today - Few Quick Q's
    Jun 2006
    Richmond VA
    Ok so i'm going to order a fusion brain today. Just a few quick questions, though. I have big dreams to have my carpc to control everything from windows, to hvac, maybe even side view mirrors as i've seen suggested. I just want to know: what are all the accessories i'm going to need to start. I know i'll need the basic brain, then maybe an 8 pack of relays, a temperature sensor, and.. anything else? How many relays are expected to be used with HVAC. I know you're working on making it easier for the HVAC with variable resistors and such, so are you going to make another part or just a software modification? If you're going to make another part, when are you expecting it to be ready?
    Thanks,
    Brett
    Fusion Brain Creator
    Mar 2005
    The trouble is, every car manufacturer's HVAC system is different. If you're asking this question, you likely can't integrate the two on your own without doing heavy research.
    We can't engineer a solution for every single car... that's up to the end user.
    Jun 2006
    Richmond VA
    Not all of my endeavors are as complex as the HVAC. I was hoping to also get my fb controlling my car windows, so maybe that'll be not as hard.. Maybe up & down on each window (2), so that'd be four relays, right?
    Don't worry, i plan to do "heavy research" and i'm a quick learner, hopefully you and toaster will be active on the forums in answering questions.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by zzzBrett View Post
    Always glad to help.
    and yes, it would be 4 relays for 2 windows. Right now, I think the guy with the most integration going on is here: http://www.mp3car.com/vbulletin/work...utomation.html
    He is doing everything. Most people have the PC start up with the car, he is having the car startup with the PC. Maybe you can get some ideas from him too.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    two relays for each window, yes.
    we will try to answer questions
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. using fusion brain to delay turn on of amp
    By theheel in forum Fusion Brain
    Last Post: 08-27-2007, 10:33 PM
  3. User Manual for Fusion Brain
    By greenman100 in forum Fusion Brain
    Last Post: 07-07-2007, 01:31 PM
  4. Car Alarm with your Fusion Brain ?
    By Fiberoptic in forum Fusion Brain
    Last Post: 07-03-2007, 02:56 PM
  5. *Available for Preorder* Fusion Brain USB I/O board
    By greenman100 in forum Hardware Development
    Last Post: 05-22-2007, 10:14 AM
