Results 1 to 5 of 5
Thread: Screw terminals!
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Screw terminals!
    I think you guys should release a small board or two that has the pin header connector on one end, and small guage screw terminals on the other. I think it would make hooking this up in a car a LOT easier =]
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by inh View Post
    You need a relay inbetween unless it is under 400mA draw. And the relays have quick connect spade connectors.
    1.9in x 2.9in -- 47mm x 73mm
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    But quick connect spade connectors dont connect to pin headers very well.. They do crimp on to wire nicely, which will in turn connect to a screw terminal quite easily =p
    If you don't wanna make em, I'll just have to do it myself! =]
    Mar 2006
    No no. There are quick connect on the relays, and then there are female pin headers attached to a 1M cable. It is as easy as possible.
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Ahhh ok =] Way to sink my cheerio =]
  1. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  2. I Have Metal Sheets - How do I Add Screw Holes
    By ccsnet in forum Fabrication
    Last Post: 04-30-2006, 06:40 PM
  3. how I can take out this screw ?
    By shinjetko in forum LCD/Display
    Last Post: 04-25-2006, 09:34 AM
  4. Recommend using Set Screw Power Rings?
    By matt11601 in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:36 PM
  5. Screw the Screw the old 'so cal meet' Thread!! Date Set 7/16/05
    By 12Vsystems in forum MP3Car Gatherings
    Last Post: 07-25-2005, 12:35 PM
