Page 15 of 23 FirstFirst ... 567891011121314151617181920212223 LastLast
Results 141 to 150 of 223
Thread: Beginning of an Automatic Climate Control System, all juiced up on Fusion
  1. #141
    Oct 2006
    Las Vegas
    that's exactly what I should have done. doh. Thanks.
  2. #142
    Mar 2006
    Colorado, but Canadian!
    And the best part is a function holds the modules properties with the designer file.
    1.9in x 2.9in -- 47mm x 73mm
  3. #143
    Oct 2006
    Las Vegas
    better now to realize this than after 12+ of these were done. Excellent advice.
  4. #144
    Oct 2006
    Las Vegas
    I know I can't do one-to-many with an input node, but inside a function, can I reference the same node multiple times, so I only need 1 connection to a variable externally inside a root function?
    Edited for clarity.
  5. #145
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Edited for clarity.
    yes I think if I understand you correctly. You mean have the function with say 1 input. But inside the function you have input1 this and input1 that, and so on right? Yup. You can also reference functions from functions (I am not sure I enabled the configurator to do this in fear of infinite recursion loops but MDX will do it if you tell it to).
    If you take a look at the IR distance sensor function included in the config functions that explains what I am saying and think you are too.
  6. #146
    Mar 2006
    IR Pic:
    That is all the same input, just used over and over and over and over
  7. #147
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    So, like all of your references to "Sensor Input" :
    <variable do="get">Sensor Input</variable>
    If they're named the same, they are the same. That's just what I was hoping. I just wish I could read and write the code better. This will be plenty of good practice. Actually, I'll just build it in the configurator and rename the variables later.
  8. #148
    Mar 2006
    Well sensor input is a temporary input variable basically. What happens is when the program hits a function it takes its known original xml, and replaces all instance off the input reference name with the name tied to its input in the code so it is seamless that way. Once the function is evaluated, the input variable name can no longer be referenced because it doesnt exist outside the scope of the function.
  9. #149
    Mar 2006
    As a side, you notice that I finally got an icon for the configurator?
  10. #150
    Oct 2006
    Las Vegas
    Perfect. Well done.
    I just noticed it today, it took a restart before the desktop icon updated. Looks good.
    I'm still going to have 34 external functions (2 x 6 output bits 1 x 5 output bits, and then the else function-counterparts) I would like to be able to re-use some, but the dial functions and settings are too unique.
  1. AIMEE Climate Control POLL
    By Danceheaven in forum Software & Software Development
    Last Post: 01-14-2010, 10:38 AM
  2. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  3. Digital dash and climate control???
    By yamathegreat in forum General Hardware Discussion
    Last Post: 10-31-2005, 05:41 PM
  4. System control wire on amp
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-13-2001, 09:09 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
