Page 22 of 23 FirstFirst ... 121314151617181920212223 LastLast
Results 211 to 220 of 223
Thread: Beginning of an Automatic Climate Control System, all juiced up on Fusion
  1. #211
    Low Bitrate Laminar's Avatar
    Oct 2008
    I skimmed through most of the thread, but I didn't happen to catch a part number for the vacuum manifold used. Would anyone that knows of a good vacuum manifold (at least 6 ports or so) care to share a part number or vehicle name?
  2. #212
    Oct 2008
    To answer my own question, I think I found the exact manifold pictured in the first post on eBay, the seller claimed it was for a '93 Lumina with the 3.1L engine, but I couldn't find the part on RockAuto. I got it for $10.
    1999 SVT Contour
    3.0
  3. #213
    Mar 2007
    Quote Originally Posted by Laminar View Post
    The Vibrant performance one isn't too bad, I wouldn't spend too much on it since it really is a simple piece.
  4. #214
    Vendor - Qube colin's Avatar
    Dec 2006
    Well for the rest of us, could you guys please explain where you found these vacuum manifolds? I've been searching eBay and Google for days and I can't find something similar!
  5. #215
    Jun 2009
    awsome project!! i was wondering i have a auto Climate control unit for my 89 crx si that im itching to install but iv noteced a few differances in wireing between the two. if anyone has any ideas on whut else i may need to scrounge up to get this thing workin let me know.
  6. #216
    Jun 2009
    figured it out thou i am interestin in whut else this thing is capable of
  7. #217
    Oct 2006
    Las Vegas
    I'm back in town... fyi, dusting things off and scratching my head, trying to figure out where I was. Taking things slow though. Anyone still looking for the vacuum module? I have one
  8. #218
    Mar 2006
    Colorado, but Canadian!
    back
    1.9in x 2.9in -- 47mm x 73mm
  9. #219
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by h3rk View Post
    Just found this thread and it was interesting to read the learning/design progress. I see a few people trying various ideas and the “universal” HVAC control idea is the hardest. Mainly with the work involved designing an elegant solution to different hardware interfaces.
    I am building a stand-alone micro-controller to replace the existing HVAC in my car. You still have full graphic display and control from the PC but everything is simplified.
    This means that only the hardware interface board would have to be changed for various installations. The HVAC control, diagnostic, trim, calibration and state information is built in. A communication link to the PC is optional and need only be used to calibrate, fine tune or select the appropriate control program (or to upload a new hardware profile to the PIC).
    The Stand-alone PIC can work with or without the physical user climate controls. If PC controlled then it powers up in Auto mode until the PC is communicating. Full Graphic display and control is a cinch. Physical controls and full graphic interface to CarPc is the mode I will most likely be operating under (Controls may go if I run out of room).
    I can certainly see why you went the way you did but in hindsight it certainly complicated things, still, you can’t beat the learning experience from doing it and quite often great final designs are the result
    My stumbling block is not the code or the interface but the finer points about the logic behind cycling the compressor from the point of fuel and cooling efficiency, do they even worry about that?
    It appears to me that (in simplified terms) some run the compressor to just short of ice up and output air temp is controlled by air mix. I would appreciate any input you have on compressor on/off time? and look forward to seeing how your design pans out.
  10. #220
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    so this is something I am pondering for my truck, I am going to follow this to see if there would be any hope of doing this on my Dodge Ram; I think it will not be too terribly complicated as the 05 is all electrically driven so its a matter of interfacing with the control unit the part that scares me is if there is a electronics module on the control head for the HVAC system.
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
  1. AIMEE Climate Control POLL
    By Danceheaven in forum Software & Software Development
    Last Post: 01-14-2010, 09:38 AM
  2. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  3. Digital dash and climate control???
    By yamathegreat in forum General Hardware Discussion
    Last Post: 10-31-2005, 04:41 PM
  4. System control wire on amp
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-13-2001, 08:09 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
