I guess you could maybe do like I mentioned above, and have 2 control heads. Use the new one with the "Auto" position as the one that is physically seen (and usually set to "Auto", letting the FB do it's thing). You wouldn't even need a motorized potentiometer, just a simple dial potentiometer hooked to a FB analog input, tracking the dial position. When the dial is on "Auto", the potentiometers on the visible dials aren't used for anything except to check if the setting is still "Auto". Then the PC can control the MOPs on the original, hidden control head to change the settings continuously without turning the visible dials.
]Now, when the dial is not on "Auto" on the visible controls, you could have the AC
software be a pass-through, with the MOPs on the hidden board copying the position of the dials on the visible board. Once again, we run into the problem of having to wait for the computer to boot, even if you want to take manual control. Maybe you could rig up an independent relay that would switch control from the hidden board to the visible board whenever the setting is off the "Auto" position? I don't quite know how you could do that, but there's got to be cut-off relays out there, that have a certain required min/max voltage value before they switch. Then you could connect the potentiometer on the visible dials to the relay, and have it completely switch a
series of relays from the MOP-operated board to the manual board whenever the manual board isn't set to "Auto", giving you a
hardware solution in case your PC dies on you.
