Results 1 to 4 of 4
Thread: Input and Output configuration questions
    Oct 2006
    Las Vegas
    I thought I'd un-bury these questions from the AC tread, I don't know if it will get answered otherwise:
    Input Question:
    Inputs have three leads: low ref, high ref, and sensed right?
    Is the low ref side the same as ground?
    Can I leave sensor low reference disconnected from the board and connect it to gnd somewhere else if I plan to use that path as a return path for current from a servo motor as well as sensor low reference?
    Will that affect sensor reading at the middle terminal?
    See http://www.mp3car.com/vbulletin/1141485-post8.html for context.
    Output question:
    Can I tie the + side of several digital outputs together, I would assume it would be fine, and that the + side of the outputs (the non transistor side) comes from one place anyway, but I thought I'd ask.
    Then again, it's not like I can get these things to work on my computers anyway
    Fusion Brain Creator
    Mar 2005
    all three wires should be run back to teh fusion brain. we sell 3 pin extensions for this.
    you can tie together the + side. ground is switched.
    Oct 2006
    Las Vegas
    Quote Originally Posted by greenman100 View Post
    bad news for me. how much current can the low side take?
    Edit: Enough for a servo motor's drive current?
    Oct 2006
    Las Vegas
    There, I bought some 3 pin extensions, are you happy now?
    I guess I'll have to hack the servo and seperate the two circuits, pre brain....thanks for the info.
  1. Kenwood Nav input & touchscreen output
    By port20 in forum LCD/Display
    Last Post: 09-03-2008, 12:38 PM
  2. Optical Input To Rca Output Converters!
    By Crazystick in forum Car Audio
    Last Post: 01-06-2006, 04:51 AM
  3. Replies: 3
    Last Post: 10-04-2004, 06:13 PM
  4. Replies: 0
    Last Post: 09-27-2004, 08:07 AM
