Results 1 to 10 of 17
Thread: Accelerometers Now Available!
    Fusion Brain Creator
    Mar 2005
    Monitor and record the G-forces that you experience while driving easily and accurately. The Fusion Accelerometer is accurate up to +/- 6G's. A typical Forumula1 race car accelerates at 1.7G's, and a typical car is between 0.3G and 0.5G. The Fusion Accelerometer insures you get the most accurate reading possible.
    The accelerometer takes 3 seperate analogue inputs which give the end user the most flexibility of any product out there. If your application only needs 1d or 2d readings instead of full 3-axis readings you may choose which of the 3 wires you want to connect.
    Includes 1m (3ft) cable for each axis (total of 3).
    http://www.fusioncontrolcentre.com/F...products_id=33
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by greenman100 View Post
    You're kidding right.
    I could tell you the G-Force with a better accuracy than 6G
    Oct 2004
    NY
    that's not the variable tolerance, that's the usable range
    Mar 2005
    Quote Originally Posted by Enforcer View Post
    It is a MMA7260QT if you want to look up specs.
    The range is +/- 6 g.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Yeah but I'm not going to stick you in my car!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Laidback View Post
    Boy am I glad about that. I've heard about your driving.
    Mar 2005
    OK, so it works between +/- 6G, but what is the accuracy?
    At worst, the error is about 5% of the measured value.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    So what you should have said is, "The Fusion Accelerometer works up to +/- 6G's and is accurate up to 5% of measured value." and not "The Fusion Accelerometer is accurate up to +/- 6G's."
    Sorry for being picky but when you are advertising something you need be be exact in what you say.
    Mar 2005
    right-o, we'll edit the website soon
