If you all know what it is that makes the hardware malfunction come up for some, on initial plug in. A fix for that would be cool with me.
So we are working on a new version of the Fusion Brain. It should be available in the next month.
So far, improvements are as follows:
13 analog inputs
16 digital outputs
what else are you looking for in the fusion brain?
Additional products on the horizon:
analog outputs
servo control
I will continue to edit this post as the design process proceeds.
Generally the fix has been on the user's end. In one case, it was a bad PCI USB card. In another case, it was an incompatible hub.
We will work to make the Brain more USB friendly for sure, but that's more firmware than it is hardware.
It is difficult to diagnose because non of Nick and I's computers have any trouble.
Maybe this might help make the new brain 'stupid-OS-proof'.
Vista,NVIDIA,Ram and Brain compatibility
I was wondering, is with the new brain the only way that the upcoming analog out will work?
1.9in x 2.9in -- 47mm x 73mm
bump.
