Results 11 to 20 of 23
Thread: problem with software install
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Yeah, that is an error with the program because I still had a call to the old dll. It was fixed in the next version. Please use the latest version 2.2.1. There is a reason why there were updates.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    when I open the 2.2.1 version, it give me an error
  3. #13
    Oct 2005
    east coast
    now I have both version on my desktop. does'nt the new version overwrite the older version? Do I put both together in the same file? or what? when I click on the fcc file and then program, I get an error has incorrect instance ID. how do I set it or fix it?
  4. #14
    Oct 2006
    Las Vegas
    these exe's aren't the kind that need to be "installed" ( yet ), so you can just delete the file that had the old one, and extract and open the new one. Now you are going to have to open the configuration file, and set the brain's instance ID to the correct value (look in hardware manager for your brain's ID under device path or instance path) there are a few threads explaining this, and they really aren't all that long. Read the other threads in the software subforum.
  5. #15
    Oct 2005
    east coast
    I copied the instance to a file in note pad. and saved it as "VIDPID.inf. I just need to know where to put it
  6. #16
    Mar 2006
    Quote Originally Posted by customaudioman View Post
    You dont need VIDPID.inf since the Beta of 2.0.
    It is actually very simple. Open the file "FusionFormDynamic.skin" in Notepad. Find the line that says "#SETDEVICEINSTANCE#MyBrain0|USB\VID_04D8&PID_000C \5&38631973&0&1" or something similar that starts with "#SETDEVICEINSTANCE#" and put in the name you want to call it in the skin file, and then the hardware id. Save, and start the program.
  7. #17
    Oct 2005
    east coast
    nevermind, I got now, thanks
  8. #18
    Newbie greaseysub's Avatar
    Dec 2006
    Mars
    Ok what am I missing here?
    edited the skin file, saved it and started the program. Still same error about SETDEVICEINSTANCE
    I've also tried "open the driver in Notepad. Then right before the string declarations, add a line called "[ClassInstall32]". That should be the only thing on the line. Save and try to reinstall."
    and repowered to no avail
  9. #19
    Mar 2006
    You dont have the correct driver installed. It should show up as "Da Fusion Brain". If it isn't, it wont work plain and simple.
    Uninstall that driver, restart. Then try with the new driver. And I need to know what the driver error is.
  10. #20
    Dec 2006
    Mars
    Ok, cleared that hurdle with your help, thanks. FYI the reason I chose the "All Drivers" initially was because under "Hardware Driver Only" it says "Included in the "All Drivers" download", thus that seemed like the "full package".
    Now, a few more questions for ya:
    In FCC after a minute or so of (seemingly) random clicking (just to test), it stops responding.
    Ok after more testing it seems to crash even if left alone running. Hmmm...
    And, where is the configure button(s)?
  1. Elmscan 5 w/bluetooth wireless obd scanner reviews
    By speedy007 in forum The Review Palace
    Last Post: 06-02-2008, 05:59 PM
  2. Problem with lilliput software
    By prnit in forum Input Devices
    Last Post: 09-08-2007, 04:23 AM
  3. VS6 and Windows XP - Install problem
    By InHoc in forum Coders Corner
    Last Post: 10-15-2006, 06:31 PM
  4. Replies: 3
    Last Post: 01-25-2006, 01:43 PM
  5. I have a Problem with Install Media Engine
    By boeschi in forum ME Archive
    Last Post: 10-13-2003, 11:10 AM
