1.9in x 2.9in -- 47mm x 73mm
The configure button died in version 1.
Everything is done in the skin file. You can use the skin designer to start configuring things. Or if you want just some simple "press button turn on output" type things then Notepad is easier.
If you need syntax, the skin designer will tell you in the text tab, or just ask here. (or maybe a different new thread since this one is sort of resolved right?).
