Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: problem with software install
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    after installing the software, I get a error message. "there are no fusion products connected to the computer that are setup for your skin file". "cause of this is #setdeviceinstance# has incorrect instance ID". can someone help me with this. I downloaded the newest version which is 2.2.1
    also in the device manager the device has a yellow question mark next to it, but it says its working properly. it don'nt say da fusion it says pic18f4550 family device.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    Which drivers did you install?
    Also, you need to check the hardware device ID, and copy that too your skin file just as the error says. Near the top of the skin file, it should say "#SETDEVICEINSTANCE#USB\VID...." and that whole thing is unique to every computer. So right click on the device in the device manager, go to driver details, hardware ID or isntance ID depending on if you are XP or Vista, and copy that number to the skin file.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2005
    my device does'nt even show up in device manager. only when I try to add new hardware it shows up as pic18f4550. then in the control panel when looking at all programs that are installed. Fusion brain does nt show up as a program.
    Mar 2006
    The software and the driver are very seperate entities.
    Make sure you are using the newest driver download (should have winusb.sys as 1 of many files).
    If it says "missing part of the inf file", add the line "[ClassInstall32]" near the end right before the strings.
    The software does not register itself in the "Add/Remove Programs" area. That requires a registry entry, and I did not want the software to be intrusive like that. Just double click the exe you download. That is the program. You can make a folder for it, make shortcuts to it, whatever you want...
    Oct 2005
    okay, I just want to start the process over, cause Im confused. So I go to your web site and download which drivers? and which program?
    Oct 2005
    do I download fusion control centre dynamic (full 1.6) or fusion control centre dynamic for xp and vista (full 2.2.1)?? what hardware drivers do I download? version 2.0, all drivers or
    hardware driver only? or what?
    Oct 2006
    Las Vegas
    You want version 2.0 drivers. You don't need the software yet to get it to show up right in device manager.
    Oct 2005
    Quote Originally Posted by 2k1Toaster View Post
    I got the drivers to work, thanks. It was missing "classinstall32" in the file. Now, which version of the software to I use?
    Mar 2006
    Glad to hear it is working now!
    Ok for software here is the thing... Version 2 is out on the website download, it is stable, it functions, it does everything, but is a PITA to skin for if you are not me apparently as my twisted mind seemed to influence it. However, Version 3 (The Uber) is only available for Beta on mp3car. I think it works fully, but I have not tested it completely so there may still be bugs. It is still in developement, but is super intuitive on skinning... So the choice is yours. I will be abondonning V2 once V3 (Uber) comes out.
    Oct 2005
    I downloaded the 2.0 version. It works when I click on the shortcut. but when I try to close the program, it has an error message. "Unable to load DLL 'mpusbi.dll'. The specified module could not be found (exception from HRESULT: 0X8007007E) I have no idea what that means. are there any updates that would fix the problem with 2.0?
  1. Elmscan 5 w/bluetooth wireless obd scanner reviews
    By speedy007 in forum The Review Palace
    Last Post: 06-02-2008, 06:59 PM
  2. Problem with lilliput software
    By prnit in forum Input Devices
    Last Post: 09-08-2007, 05:23 AM
  3. VS6 and Windows XP - Install problem
    By InHoc in forum Coders Corner
    Last Post: 10-15-2006, 07:31 PM
  4. Replies: 3
    Last Post: 01-25-2006, 02:43 PM
  5. I have a Problem with Install Media Engine
    By boeschi in forum ME Archive
    Last Post: 10-13-2003, 12:10 PM
