Results 21 to 30 of 38
Thread: few questions about hook up of fusion brain
  1. #21
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    whats next?
  2. #22
    Mar 2006
    Colorado, but Canadian!
    If you are absolutely sure those are voltages, then just connect it to the input of an analogue input, and then all you have to do is the set the skin file.
    But voltages DO NOT equal resistances. In your post you say resistances, so I want to make sure you dont blow up the brain. You need to know what is what...
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Oct 2005
    this is what i did. I set the MM TO 20DCV. Thenput the positive terminal on the wire and the negative to the ground of the car. pressed each button, which gave me the voltage.
    the voltage for each button wasnt the exact the same every time I push the button. for example the mode button would go back and forward between 3.39-3.97 and vol button up 1.0 - 1.08 and vol down would be 0.3 - 0.37. but whenI tap the button it would be a different reading every time, but always between those numbers I listed. If I pressed and hold the butons, it would give me the same every time.
  4. #24
    Mar 2005
    Quote Originally Posted by customaudioman View Post
    Make a table of all voltages, with press and hold. Post that here.
    If you press and release quickly, the MM will have to guess at the voltage, so to speak.
  5. #25
    Oct 2005
    Quote Originally Posted by greenman100 View Post
    These are the voltages when I press and hold. No buttons pressed the wire reads 3.9v,
    and the first button when pressing the vol-up 1.08v, vol-down 0.37v, 2nd button ch button, it reads ch-up
    2.66v, and ch-down 1.82v . the third button is the mode button, fm,am,cd,aux anyway it was 3.39v when pressed. these are reading that I got after holding the button for a few sec. So, since none of the values are over 5volts, I would not need any resistors, correct?
  6. #26
    Mar 2005
    correct. Just hook up the analog input to wherever you measured. Then, set the software up. Nick can help from there.
  7. #27
    Oct 2005
    thanks for everything, since I have just three buttons on the steering wheel, I would just use three analog inputs? two of the buttons each has two functions(one vol-up and vol- down) the other (track- forward and track -back) are they still one input on the fusion brain each or is each function separate? thanks
  8. #28
    Oct 2006
    Las Vegas
    I'm pretty sure you can hook up your 1 wire to 1 input. That's the idea here right. What you can then do is define things that can happen in the skin which depend on that 1 inputs value.
    (This is if you are using FCC Uber edition)
    so you define and name an analog input, then in the logic section of the skin you can use the value of the analog input to toggle new variables, which can then be used... well, however you want
    Code:
    <iochannel id="SteerCom" port="1" brain="MainBrain" type="analogue_input">
    then:
    initialize some variables:
    Code:
    Vol-Up = 0
    Vol-Dn = 0
    Ch-Up = 0
    Ch-Dn = 0
    Mode = 0
    StrComErr = 0
    if SteerCom < 4.5 & SteerCom > 3.55V
       then all variables = 0
    else if
       SteerCom is > 3.05V
          then mode = 1 and all others = 0
       else if
          SteerCom is > 2.25V
             then Ch-Up = 1 and all others = 0
          else if
             SteerCom is > 1.45
                then Ch-Dn = 1 and all others = 0
             else if
                SteerCom is > 0.75
                   then Vol-Up = 1 and all others = 0
                else if SteerCom is > 0.2
                   then Vol-Dn = 1 and all others = 0
                else
                   StrComErr = 1 and all others = 0
    This code isn't actual and you would have to go by the examples in the configuration file. I think this would have to be done in the UberFCC release, to do it in this general way. The psuedocode sucks, but I hope it puts the point across, or elicits a response from the expert.
    The values I chose were to split the difference between the values to minimize non-responsiveness. False positives might occur though, if so the bands could be tightened.
    And the err variable could make some error message or indicator happen or even go into the log. But then you have now some digital signals (the variables) that you can use to make things happen with.
    (I don't quite know how FCC will communicate to make volume change in windows, or tracks and mode for PC-radio usage yet).
  9. #29
    Oct 2005
    Quote Originally Posted by h3rk View Post
    Code:
    then:
    Code:
    Vol-Up = 0
    Vol-Dn = 0
    Ch-Up = 0
    Ch-Dn = 0
    Mode = 0
    StrComErr = 0
    else if
       SteerCom is > 3.05V
       else if
          SteerCom is > 2.25V
          else if
             SteerCom is > 1.45
             else if
                SteerCom is > 0.75
                else
    so even since I have three buttons on the steering wheel, I only have to use that one input for all three buttons?
  10. #30
    Mar 2006
    yes. that is the whole point of a resistance varying wire system...
  1. New project please help with some questions
    By gt__1 in forum Fusion Brain
    Last Post: 10-05-2007, 02:49 PM
  2. Brain cells CAN reproduce!
    By XxAndyxX in forum Off Topic
    Last Post: 02-28-2007, 07:55 PM
  3. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  4. Replies: 1
    Last Post: 04-10-2005, 06:24 PM
  5. starting project soon, questions..
    By tekknikal in forum General Hardware Discussion
    Last Post: 05-28-2002, 07:47 PM
