Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: Connecting resistive "steering wheel media buttons"
  1. #31
    Dec 2007
    Victoria, Australia
    Question
    Does this look right?
    Have I missed something, as its not working?
    thanks again
    Code:
    	<io>
    		<brain id="MainBrain">USB\VID_04D8&amp;PID_000C\5&amp;1507E3A6&amp;0&amp;1</brain>
                             <timer id="logic" interval="65"></timer>
    		<timer id="gui" interval="30"></timer>
    		<timer id="output" interval="100"></timer>
    		<timer id="input" interval="50"></timer>
        <iochannel id="SteeringWheel_Sence" port="1" brain="MainBrain" type="analogue_input">
          <options history="100" auto_average="false"></options>
        </iochannel>
    	</io>
    	<logic>
    		<all_variables>
    		</all_variables>
        <all_logging>
        </all_logging>
        <all_statements>
          <!-- **   Button UP   ** -->
              <if fire_on="logic">
            <parameter1>
              <if>
                <parameter1>
                  <analogue id="SteeringWheel_Sence" time="0"></analogue>
                </parameter1>
                <test check="greater than or equal to"></test>
                <parameter2>
                  <number>.1</number>
                </parameter2>
              </if>
            </parameter1>
            <test check="AND"></test>
            <parameter2>
              <if>
                <parameter1>
                </parameter1>
                <test check="less than or equal to"></test>
                <parameter2>
                  <number>.5</number>
                </parameter2>
              </if>
            </parameter2>
            <then>
              <do function="send key" functionTargetID="centrafuse" vote_opinion="CTRL::F" vote_priority="medium"></do>
            </then>
          </if>
          <!-- **   Button DOWN   ** -->
            <parameter1>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>.6</number>
                </parameter2>
              </if>
            </parameter1>
            <parameter2>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>2.9</number>
                </parameter2>
              </if>
            </parameter2>
            <then>
              <do function="send key" functionTargetID="centrafuse" vote_opinion="CTRL::B" vote_priority="medium"></do>
            </then>
          </if>
                <!-- **   Button MODE   ** -->
            <parameter1>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>3.0</number>
                </parameter2>
              </if>
            </parameter1>
            <parameter2>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>3.5</number>
                </parameter2>
              </if>
            </parameter2>
            <then>
              <do function="send key" functionTargetID="centrafuse" vote_opinion="F8" vote_priority="medium"></do>
            </then>
          </if>
                <!-- **   Button VOLUME UP   ** -->
            <parameter1>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>3.6</number>
                </parameter2>
              </if>
            </parameter1>
            <parameter2>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>4.2</number>
                </parameter2>
              </if>
            </parameter2>
            <then>
              <do function="send key" functionTargetID="centrafuse" vote_opinion="F10" vote_priority="medium"></do>
            </then>
          </if>
                <!-- **   Button VOLUME DOWN   ** -->
            <parameter1>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>4.3</number>
                </parameter2>
              </if>
            </parameter1>
            <parameter2>
              <if>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>4.6</number>
                </parameter2>
              </if>
            </parameter2>
            <then>
              <do function="send key" functionTargetID="centrafuse" vote_opinion="F9" vote_priority="medium"></do>
            </then>
          </if>
        </all_statements>
    	</logic>
  2. #32
    Mar 2006
    Colorado, but Canadian!
    1) Centrafuse's window could be wrong
    2) You are sending "ctrl" and then "f" , on a button press, not CTRL and F at the same time. Currently CTRL and another key at the same time doesnt work. Simple 1 key commands are best.
    And to find Centrafuse's Window or class, a program like Spy++ is helpful. Or a quick PM to David would be good.
    I dont have Centrafuse or StreetDeck, so I cannot help with that part.
    But other than that, everything looks good.
    If you try with title of "winamp" (and of course have winamp running" the keypresses should work.
    And the only titles that work with 1 liners is "winamp" for Winamp, and then "wmp" and "windows media player" for windows media player.
    Otherwise it is "title:class" or if there is a subclass/subwindow it is "title:class:subtitle:subclass". THey dont all have to be equal, but if you only have the title, then you have to put "title:" (notice the colon after it), and it will disregard the class. But if it cannot find the window based off of that title, then it will error out of the command, and just do nothing. Make sense?
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    Mar 2005
  4. #34
    CwF
    CwF is offline
    Jun 2008
    Denver(ish)
    I've read thru it all and think I might be missing something. Where do we tale into account the varied vehicle voltage? would not the voltage the FB reads need to be a small range to trigger and not a specific voltage? Normal range for my truck running can drop from a no load 14+ to high 12. Off could be 12.8-12.0, lower under auxiliary batteries.
    wondering...
    06 Silverado LBZ wants onboard everything...
  5. #35
    Mar 2005
    you'd need to install a voltage regulator or a vehicle voltage sensing circuit that changed the setpoints in the MDX logic
  6. #36
    Dec 2005
    Raleigh, NC
    Here's the diagram for my steering wheel (steering wheel in upper left corner):
    I'm a mechanical engineer and I'm a little rusty on my e-sci. Would I end up needing to hook power to the steering wheel control (A3 GRN/Red - remote) and then hook (A14 brown - steering wheel ground) to the FB? The pins for A3 and A14 are in the harness and the rest of the stuff is the stock stereo which is coming out. I could get 5v from the power supply in the computer but I'd prefer to stick with not having to do that if I can get away with it.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  7. #37
    Mar 2005
    you'll want to disconnect A3 and A14, then follow the instructions for 2-wire controls in the documentation section of this forum.
  8. #38
    Dec 2005
    Raleigh, NC
    Thanks greenman. I looked at the tutorials and since it's not powered I think I'll need to measure the maximum resistance and then use solution D. I guess the next step is to buy one and play around with it.
  9. #39
    Dec 2005
    Raleigh, NC
    So if I understand things correctly here is what I think I need to do:
    1. Measure maximum resistance from steering wheel (have 4 buttons so need to test them)
    2. Buy a resistor of similar value
    3. Connect ground from steering wheel to ground on FB
    4. Connect signal from steering wheel to input on FB
    5. Use the resistor I bought and jump from the +5v to the input on the FB (also connected to steering wheel output).
    Then hook it up as follows:
    Does this sound correct?
  10. #40
    Mar 2005
    yup.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. Windows Vista W/nView!
    By 97GST in forum Operating System Optimization
    Last Post: 04-01-2006, 09:46 PM
  4. Beyond Media out tomorrow!!!
    By Defiler in forum Software & Software Development
    Last Post: 12-04-2004, 02:27 AM
  5. neocar media center EN version, here it is :)
    By netsuo in forum NeoCar Media Center
    Last Post: 10-04-2004, 01:36 PM
